E90Post
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > Which eccentric shaft sensor
      05-10-2024, 11:10 AM   #1
sharadn
Drives: 2010 bmw 328i xdrive wagon
I am about to replace the valve cover on my 2006 325xi wagon and would like to have on hand the eccentric shaft sensor in case mine is showing signs of oil infiltration. FCPro has VDO, Vemo and BMW. Suggestions?
      05-10-2024, 12:16 PM   #2
mainbearing
Drives: BMW 328i
Continental/VDO. I believe that is the OEM manufacturer and BMW just puts its name on it.
      05-11-2024, 09:51 AM   #3
sharadn
Can I tell if I have an oil problem before I remove the valve cover?
      05-11-2024, 11:04 AM   #4
mainbearing
Drives: BMW 328i
What type of oil problem?
If there is no oil in the ESS connector, the sensor is probably still good. It is good to have one on hand, and may be a good idea just to replace it?
      05-11-2024, 11:17 AM   #5
sharadn
I pulled the connector off the sensor and there is a little oil in there so I will go ahead and replace. Thank you!
      05-11-2024, 12:01 PM   #6
mainbearing
Drives: BMW 328i
Yes that is a sign the ESS sensor is bad. Time to replace!
e90post
