05-19-2016, 12:27 PM | #1 |
Rep 69
Shop for rod bearing replacement
I'm located just south of Baltimore and I'm looking for a reputable shop to do my rod bearing replacements. If any of you have personally had your bearings done in the DMV, please let me know.
I'm also willing to have it done by an individual if the reputation is legit. Thanks! |
05-19-2016, 02:28 PM | #2 |
Rep 562
I've heard TTFS is a good place to go for this job.
or RRT I would imagine either one is gonna cost you a pretty penny.
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
05-19-2016, 02:37 PM | #3 |
Rep 518
I'll PM you a guy who is a BMW tech in your area and does this on the side. Much cheaper than any shop will charge, too.
-Josh
2003 M3 | SMG | KW V1 | Apex ARC-8s | 3.85 LSD | Cobra Nogaro | S2R Tuning Sunroof Delete | Billy Boat Section 3
05-19-2016, 03:00 PM | #4 |
Rep 1,407
Drives: 06' E46 M3 ZCP
Am I wrong when I say that the research on the rod bearing issue suggests that this problem is more susceptible to the 08-10 models?
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock |
05-19-2016, 10:22 PM | #5 |
Driver
2692
Rep 2,714
Yes, based on the data present in the forums that would appear be incorrect or at least undetermined. Additionally, the level of wear on the bearings doesn't seem to be traceable via oil analysis on the 2011+ models due to the different materials used.
05-19-2016, 10:47 PM | #6 |
Rep 1,755
Don't go to RRT unless you have shit load of money that you want to waste
Day Laborer1749.50 |
05-20-2016, 09:36 AM | #7 |
Rep 1,407
+1
To say the prices they quote you are inflated would be understated. They probably do good work, but their quotes are an immediate turn off. I'm all about paying for quality, but they charge God prices.
05-20-2016, 09:48 AM | #8 |
Rep 1,385
as of late I've seen more 11 and ups spinning rod bearings but they also all seemd to be cars driven but those who only go to the dealer on that 14k mile interval so no surprise there.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
05-21-2016, 09:20 PM | #9 | |
Rep 461
"Newer factory bearings (2010.5 and later) are made from tin-aluminum, not lead-copper. Tin-aluminum bearings are 4-times harder on the surface than lead-copper bearings. This extra hardness shows signs of doing more damage to motors as there seems to be more bearing failures with 2010.5 and later vehicles. Tin-aluminum bearings also don't show the same signs of premature wear in Blackstone oil analysis due to lack of lead and copper."
16 M4 / 17 C7 (Sold) / 08 E92 M3 AW (Sold) / 09 Yamaha R6 (Sold)
05-21-2016, 09:22 PM | #10 |
Rep 461
+1, this guy has done bearing replacements for a couple of M3 and M6 owners. I've had him work on my previous 335i as well.
05-27-2016, 07:37 AM | #11 |
Rep 1,001
please send me his info too! thanks
| 2008 E90 M3 | Alpine White | 6MT |
06-08-2016, 04:47 PM | #12 |
Rep 257
06-23-2016, 05:31 PM | #15 |
Rep 518
Also check out GT Peace in Chantilly.
01-04-2017, 06:38 PM | #18 |
Rep 1,003
Drives: 2008 E90 M3 DCT Silverstone II
Check with S2 Dynamics. They might be able to. Great team, good pricing, solid work.
Current: 08 E90 M3 DCT SSII w/ BE RB Swap, H8 Lux 180s, MS Drop-in AF, CF spoiler, CF diffuser, OEM CF leather trim, CF DCT paddles, Custom DCT flatbottom wheel, MirrorTap 9500ix, RockAuto rotors, Hawk HPS pads, AMS ECU 93 Oct Map Tune, GTS DCT update, Slambo custom undertray
01-05-2017, 08:30 AM | #19 |
Rep 438
02-17-2017, 01:10 PM | #21 |
Rep 69
I ended up getting my BE Bearings installed by a highly reputable private tech in the Gaithersburg area. I can share info if anyone is interested (PM Me).
Don't get me started on Flemming... Long story short, and I can't speak for their techs, after multiple phone conversations with the owner (Co-owner, as he so graciously pointed out to me over the phone), I wouldn't trust this place with a job that requires this level of attention to detail. I'm sure the techs are knowledgable but that guy left me with zero confidence that the job would be done correctly. It started when I asked if there was a labor-charge difference between using OEM bolts vs ARP (considering the tightenting proceedure). He said "no, we install all bolts the same way"... |
