07-17-2023, 09:31 PM | #1 |
Rep 4,554
Drives: 2015 328d xDrive
2015 328dx 8AT - 85k miles
Kerma stage 2 added ~ 3 months ago Trans service done at 70k Tonight I was parking in reverse on a slight incline and the trans slipped into neutral by itself. I tried to put in back into R and I could not. I drove away in drive and got two codes thrown on my idrive. They are posted below from BimmerLink. I shut the car off and turned it back on and all is normal. Should I be concerned? Is this something others have experienced? And if so, what was the issue? Could this be something as simple as needing an adaptation procedure? Or is this my transmission on its way out? Enabled
07-18-2023, 07:13 AM | #2 |
Rep 368
My car just recently had a similar issue. I pulled into a tollway oasis, went to put it in reverse to pull out of my spot and it grinded, thought I had run over the parking block or something (though my car is too low to get over most parking blocks lol). Got out and looked, clear of the parking block. Hopped back in and went Park->Neutral->Reverse a few times with the same noise, car wouldn't move. Shut off the car and restarted and it went into reverse fine.
I ended up rebuilding the transmission mechatronics unit with new solenoids and a zip kit to resolve the issue. The car was also shifting harshly on the 1->2 shift, the 2->3 shift, and downshifts in the low gears so I suspected issues prior to this occurring. My mileage was about 230k, with changes every 60k since new. I would suggest checking the fluid level first and inspecting for any possible leaks... Fluid should drip out of the fill plug with transmission oil temp warmed to 40* C. That wasn't my issue, but low fluid will cause a variety of shifting issues. Did you use ZF8 fluid when you changed it? The mechatronics seal is a place where these transmissions are rumored to leak and should also be inspected. The mechatronics seal is the grommet that the electrical connector on the back of the transmission plugs into, I would inspect that closely. If there's any evidence of leaking under that connector that's likely it. I never replaced the seal until I rebuilt the mech unit, but it can be replaced while you have the pan off to change the fluid. Last edited by kdog_x; 07-18-2023 at 07:31 AM.. |
07-18-2023, 07:38 AM | #3 | |
Rep 4,554
I don’t wrench on my car myself so I can’t tell you what fluid was used and if enough was added, a mechanic did that for me. I’m pretty sure they used a kit from FCP euro in which case the correct fluid should’ve been supplied. Hoping this is a quick and easy fix, I’m only at 85,000 miles so I’d be very surprised/disappointed if this ends up being an expensive/serious issue.
NYC Bimmer259.50 |
07-18-2023, 11:19 AM | #4 |
Rep 1,821
For this scenario, if it were my car and the fluid level is correct, I'd want the car to be scanned with ISTA to determine the conditions under which the errors happened and have ISTA run the test plans designed around these codes. Implausible gear ratios can mean a lot of things, including sensor disconnected, or loss of fluid pressure, or other things.
-2014 328d Wagon, 8HP. Self-tuned, 270hp/430ft-lbs.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. |
AndrewC198910949.00 |
