08-12-2014, 03:15 PM | #1 |
Rep 355
New suspension
I'm considering upgrading my suspension to the KW Clubsport or the JRZ RS1. Is one system recommended over the other? I believe they both come with camber plates. the complete kits with dampers, springs and camber plates.
Thanks for any info provided. |
08-12-2014, 05:51 PM | #2 |
Rep 6,734
KW Clubsport is the most common, tried, and true option for the M3. JRZ makes great products and I don't think you can go wrong with either option.
'23 X7
08-12-2014, 06:58 PM | #3 | |
Rep 7,298
08-12-2014, 07:48 PM | #4 |
Rep 5,701
JRZ or MCS dampers. Each damping adjustment has a noticeable effect on handling/balance. Good street manners even with track-biased spring rates.
08-14-2014, 03:49 PM | #7 |
Rep 5,701
08-14-2014, 03:52 PM | #8 | |
///M Powered for Life
11500
Rep 10,332
Are we talking about the 2 ways or the 1 way? Including camber plates, etc etc An apples to apples comparison vs the KW CS 2 ways PS: I like that your wife drives a E92 M with JRZ suspension!! |
08-14-2014, 04:03 PM | #9 | |
Rep 5,701
Thanks! She loves her M3...JRZ suspension is not the only mod |
08-14-2014, 05:48 PM | #10 | ||
Rep 1,681
08-14-2014, 08:45 PM | #13 |
Rep 381
+1 on the MCS 1-ways.
I would caution against the JRZ RS-1 dampers. Though JRZ is highly regarded they have had problems with the RS-1 struts, including the set I had on my car. They were excellent for 9-10 months but the fronts got progressively stiffer and noisier. Interestingly, BW only noticed problems with 1M's even though they use the same unit as for the M3. You'll notice BW doesn't sell the RS-1's anymore also. Though JRZ USA was willing to handle my warranty claim JRZ Ned was not and I ended up with the MCS units. Props to BW for stepping in and taking care of me.
08-14-2014, 10:10 PM | #14 |
Rep 1,470
I am going with MCS 2-way non-reservoir dampers.
08-16-2014, 11:03 AM | #16 |
Rep 5,701
I disagree. JRZ and MCS dampers have improved ride qualities over the stock suspension, even with track-biased spring rates. I'd recommend them for street-only and track-only setups.
08-16-2014, 11:43 AM | #17 |
Rep 1,239
CS or JRZ
IMO KW Clubsports is a great suspension for both track and DD out of the cereal box. Plus, it's quiet. I've had both the new and old version. I currently have the JRZ RS w/ Swift Springs, GC arms etc, etc. Suspension that you need to piece together according to your application or liking. My major complaint is that it's noisy and I'm not alone on this. JRZ two-way dampers have a little more setting to choose from but performs just as great as the KW CS. I switch because I just wanted to try something different. GL
2016 Hellrot F80 M3|JRZ RS Pro with Swift Springs 550/750 spring rates l AP Radical 5000R 9668/9449 lSpiegler SS LinesI DS1.11I Eisenmann DP|MPE Catback|18" Forgeline GS1R 18x10 et 22 and 18x11 et 44 NT01 275/35/18 and 305/35/18| Forgeline GTD1 18x10et43 SquarelM Performance Lip/Splitter|IND aesthetic mods|Dinan Toe Link|Fall Line mono ball conversion kit and upper link kit| Aim Solo 2DL Smarty Cam|Simpson Hybrid|Stilo Offshore helmet.
08-16-2014, 07:34 PM | #18 |
Rep 44
My setup is this. Been very happy. Very noticeable a on couple clocks up/down on comp/rebound. Great customer service from the manufacturer. Lex actually called me few times to discuss couple things after I installed them ran them at the track.
08-16-2014, 07:39 PM | #19 |
Rep 1,239
Suspension
I made an error on my post above. It's not my JRZ RS dampers that are making noise but my GC sway bar end links that are making noises. Someone I know have used silicone and grease to make the noise go away but it comes back after a few months.
09-01-2014, 10:58 AM | #20 | |
Rep 7,298
this is what I'm getting at, not how good the ride is for the street. |
09-01-2014, 11:26 AM | #21 |
Rep 5,701
09-01-2014, 11:32 AM | #22 | |
Rep 7,298
and i agree with you, good suspension setups are way better performance and comfort on the street. |
