      08-21-2023, 01:27 PM   #1
woodsjbw
woodsjbw's Avatar
Drives: e92 2011 m3 coupe
Higher oil temp than Normal
Noticed the M's oil temp has been running a little higher than normal. Ran the OBD and got:
P316B/ Engine Coolant Temp Signal Stuck
P0116/ Engine Coolant temp Circuit Range/ Performance
P0128 / Coolant t-stat regulating temp
It has around 87k miles. Already know it's time to Replace the T-stat, and might as well do the water pump, just looking for some thoughts on what else I should look at before throwing money at the issue.
      08-22-2023, 11:52 AM   #2
panda-R
Drives: 2008 E90 6MT
Do you have a leak?
Is the overflow bone dry?
the t-stat and t-stat sensor is cheap.
The water pump isn't cheap but it is what it is but u don't have to really change it till it gives out.
      08-22-2023, 12:14 PM   #3
woodsjbw
woodsjbw's Avatar
Originally Posted by panda-R View Post
Do you have a leak?
No leaks. Don't notice any residue on the ground or anything. I took it to the dealership to have the oil change, and fluid check. So, all is good in that regard. It's a little weird to be replacing these parts again seeing that I did it back in Jan of 21', but I think the shop I went to didn't replace them with OEM parts.
      08-22-2023, 12:29 PM   #4
panda-R
hard to speculate what the dealership did unless you watched them or know what they put in.
the t-stat and the sensor are pretty easy DIY if you want to know if it was done or done properly.
      08-22-2023, 12:54 PM   #5
woodsjbw
woodsjbw's Avatar
Already have the parts on order for the T-stat and Sensor b/c that's what the OBD2 is saying so we'll see how it goes once that's done.
      08-26-2023, 06:40 PM   #6
s0ldats
Drives: 2011 E90 M3 stripper
out of curiosity, what is higher than normal?
      08-28-2023, 01:42 PM   #7
woodsjbw
woodsjbw's Avatar
on the way up to Stockton from Monterey it was fluctuating between 240-270.. Now it was a littler warmer outside around 90 degrees. But I don't want to take any chances, especially since I was getting codes.
      08-28-2023, 11:01 PM   #8
s0ldats
were the codes triggering CEL? or just when you scan
      08-30-2023, 10:25 AM   #9
woodsjbw
woodsjbw's Avatar
The CEL light is always on b/c I run ITB's (velocity stacks) an Alpha N tune & no plenum. HOWEVER, I usually only have the increased emissions code P0068 MAP/MAF sensor because the IAT Sensor is not plugged into the Plenum anymore. still haven't figured out a way to remedy that one..
But when I scanned this time, I got all the other codes referencing the T-STAT.
I confirmed its bad, so I am in the process of replacing it along with the sensor. Not messing with the housing or the pump.
      08-30-2023, 10:41 AM   #10
woodsjbw
woodsjbw's Avatar
Pic we took before the finished ITB project just for reference.
      08-30-2023, 10:53 AM   #11
Brandoch
Brandoch's Avatar
Drives: 2009 E93 M3 DCT
Your doing a project like that but still don't have a BMW scanner?
      08-30-2023, 11:11 AM   #12
Brandoch
Brandoch's Avatar
P codes are not bmw codes
      08-30-2023, 11:13 AM   #13
woodsjbw
woodsjbw's Avatar
You're talking about a BMW Specific, I've got a Regular OBD scanner. Ill look into grabbing another one. any recommendations for the best one?
      08-30-2023, 11:19 AM   #14
Brandoch
Brandoch's Avatar
Foxwell, ISTA/ INPA, Protool, ect... just not carly
      08-30-2023, 11:25 AM   #15
woodsjbw
woodsjbw's Avatar
Thumbs up
Thx Man, the projects been done. I've run this set up for a few years not issues. Just the IAT sensor thing i Mentioned.
      08-31-2023, 11:55 PM   #16
s0ldats
keep us posted if the t-stat corrects your issue !
      09-01-2023, 06:48 AM   #17
Soden82
Drives: 2011 BMW M3
2011 BMW M3  [0.00]
Any normal foxwell will do?
2009 BMW 335i 6MT
*big single (eventually)*
For now...
MHD tuned
VRSF Race IC
DCI
ATM exhaust
      09-01-2023, 08:51 AM   #18
tdott
Drives: M3
Carly is better than a generic code reader imo.
      09-01-2023, 03:01 PM   #19
Brandoch
Brandoch's Avatar
NT510 and 530 are popular. Im not sure if all of foxwell scanners will work for BMW specific codes, but there are a lot of them that will.
Soden82478.50
      10-11-2023, 05:46 PM   #20
woodsjbw
woodsjbw's Avatar
Tstat was the issue all good to go!
Tags
codes, coolant, maintenance, oil temp, p0128, p316b
