F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > Best spark plug for E30 Applications
proTUNING Freaks
      12-21-2021, 07:30 PM   #1
socalengineer
Drives: 640i F13 Alpine White
Hi,
Which is the best spark plug for E30 applications?
I heard NGK 97506, as well as BMW 12120042724 FLEX FUEL SPARK PLUGS.
Which gap to use?
I'm currently on a Bootmod3 stage2+ e30 tune. Might go Pure Stage 2 in the future. Won't be going full E85, just keeping E30 for fuel economy.
Thanks in advance.
https://bootmod3.atlassian.net/wiki/...+and+which+gap
      12-21-2021, 07:37 PM   #2
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Originally Posted by socalengineer View Post
Hi,
Which gap to use?
Thanks in advance.
there isn't a best. you wanna run the hottest plug you can without having timing corrections.. also the largest gap you can without having misfires. so.. yeah, it depends.
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      12-21-2021, 07:58 PM   #3
thejeremyman9
thejeremyman9's Avatar
4368
Drives: 2015 BMW 335i
Stock plugs stock gap.
johnung4531.00
harkes1085.50
      12-21-2021, 10:33 PM   #4
socalengineer
But I am running more boost and timing? Bootmod3 recommends NGK 97506:
I am also tuning a friends car, N55 PWG, with a Pure Stage 2 Turbo. They are running the NGK 97506 as well, just wondering if there is a better option.
      12-22-2021, 04:02 AM   #5
n55david
n55david's Avatar
2015 X3 x35i  [0.00]
doesnt.matter if you're stock or not tbh..
and no, there is no better options.
johnung4531.00
      12-22-2021, 05:57 AM   #6
lucasborka
lucasborka's Avatar
41
Drives: BMW F36 435i FBO
2015 BMW 435i   [7.50]
Stock is the way to go.
Bosch ZR5TPP330 at stock gap. You want the biggest gap possible without spark blowout for a more complete combustion. Better combustion better power
      12-22-2021, 12:00 PM   #7
thejeremyman9
4368
Yes, i know what BM3 says, which is why so many people blindly follow that advice and swap in colder plugs with a smaller gap that they don't need.
My 45k mile OEM plugs did fine at E30 before i changed them and replaced with new OEM... also people run OEM plugs with PS2, meth, etc all the time.
Correct
      12-24-2021, 10:04 AM   #8
Pussiwillow
Drives: Alpine white 2014 335i msport
Another vote for stock plugs, stock gap.
      12-24-2021, 10:41 PM   #9
harkes
harkes's Avatar
China
1086
Drives: M135i, E39 M5, NSX and AE86
Stock plugs at stock gap = winner... See my mods in the description
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
      12-26-2021, 06:07 PM   #10
socalengineer
My tuner had me put in NGK 97506 @ 0.18", I'll stick with his recommendation and tune the car like that. Then I'll switch maybe to the stock plug and stock gap, see if I don't get timing pull/lose power. Sounds like a good plan?
      12-26-2021, 07:48 PM   #11
johnung
Correct
I've got Bootmod3. A few years ago they recommended NGK 97506 gapped down to 0.022" for their N55 Stage2 tunes. Later they came out with that spark plug article that makes it sound like they recommend them for all of their N55 tunes, including Stage1.
I contacted them and pointed out that by default a Stage1 tune is supposed to mean that the hardware is all stock. (Except of course for the poorly designed F30 N55 chargepipe) As far as I know they ignored my suggestion to clarify that stock plugs & gap should used for BM3 Stage1.
Guys are so used to looking for and assuming that every part has an upgrade. There is no such thing as a spark plug upgrade! BMW engineers chose the stock plug and gap because it provides optimal performance for the engine.
With spark plugs- if it ain't broke don't fix it. If it's running fine, then there's no upside to changing plugs/gap. It can't get better. It can only get worse!
"Spark blowout" was mentioned as a reason for different plugs/gap. Spark blowout is actually a misnomer. The spark doesn't blow out. It never gets started. It can happen with very high boost tunes because they jam a much higher than usual number of fuel and air molecules into the engine cylinder. It creates a traffic jam of sorts. One solution would be electronics with a stronger spark like a race team might do, but it's easier to switch to a colder plug with a shorter gap. But there's often a trade off. For example an engine may not idle as smoothly.
For a newly tuned N55, I would suggest installing a set of new stock Bosch plugs at stock gap out of the box. There are about $9 each. Then see how it runs. Learn how to collect logs. If there are issues never suspect plugs first. Always make sure that fuel quality is high enough. If local 93 gasoline quality is suspect then add 1-2 gallons of E85 to the tank. Or flash down from the 93 tune to the 91 Octane tune. If those things improve engine smoothness and performance then it's fuel quality not a spark plug issue. There are plenty of posts about how to visually inspect plugs to determine how an engine is running.
Hope this helps someone!
      12-27-2021, 12:14 PM   #12
thejeremyman9
4368
That gap is extremely small for the vast majority of people. Unless you have some extreme setup/fueling/etc its probably totally unnecessary. If your tuner requested it then go for it so the car behaves as they are expecting but that doesn't mean its the ideal setup.
      12-27-2021, 02:04 PM   #13
lucasborka
lucasborka's Avatar
41
Correct
Very well explained! Pin it😅
johnung4531.00
      04-13-2024, 03:24 AM   #14
California209
Drives: BMW F30 328i
2018 BMW M5  [0.00]
Hi,
Which gap to use?
Thanks in advance.
The Reason Bootmod3 recommends 1 step colder is for ever 100HP you want 1 step colder. So i am running E30 and with all my mods and even though ethanol burns colder, we'll I guess that's when you need to figure out how much HP you have above stock. Then you can make a educated guess to go colder or not. Get a Dyno then go from there!
      04-13-2024, 03:28 AM   #15
California209
2018 BMW M5  [0.00]
FYI as to how much HP I am running it's about 150 over stock.
      04-13-2024, 11:30 AM   #16
5w20
@_sunbish
5w20's Avatar
284
Drives: Bmw 435i & 340i
NGK 97506 with out of the box gap, .031”.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5
f30post
