11-07-2023, 11:50 AM | #1 |
Rep 116,006
N54Tuning.com - MAD BMW M340 M440 B58 High Flow Air Intake W/ Heat Shield - ON SALE!
ORDER LINK https://www.n54tuning.com/mad-bmw-m3...at-shield.html Introducing the MAD BMW M340 M440 High Flow Air Intake W/ Heat Shield - a groundbreaking system designed specifically to elevate your BMW M340 M440 to new performance heights. Precision-engineered, this intake system harmoniously blends enhanced functionality with an added touch of elegance to your driving experience. Unearth the latent power of your BMW M340 M440 with our High Flow Air Intake. Manufactured from the highest-quality materials, this intake assures unbeatable durability and continuously supplies fresh, cool air to your engine, thereby augmenting throttle response and fuel efficiency. One of the key aspects of our intake system is the Heat Shield. This significant feature effectively combats heat soak - a common barrier to performance in turbocharged vehicles. By efficiently isolating hot engine air and ensuring the coolest air is channeled to your turbocharger, you'll notice an uplift in performance throughout the RPM range. Key Features: Direct Fit: Tailor-made specifically for the BMW M340 M440, guaranteeing perfect fitment without any requirement for modification. High Flow Design: Fully utilize your engine's capabilities with a steady supply of cool, dense air. Heat Shield: The included heat shield wards off hot engine air, ensuring that only the freshest, coolest air is supplied to your engine, maximizing power output. Superior Quality: Constructed with top-tier materials to ensure enhanced durability and extended service life. Improved Throttle Response: Offering a more streamlined path for air to reach your engine, our intake system significantly enhances throttle response. Increased Fuel Efficiency: Better airflow can lead to improved combustion and enhanced fuel economy. No Check Engine Light Lifetime Warranty: As with all MAD products, this air intake system comes with a lifetime warranty, ensuring long-lasting peace of mind. The MAD BMW M340 M440 High Flow Air Intake W/ Heat Shield is not merely an accessory; it's a significant stride towards superior performance enhancement. With this addition, you will not only feel the improvement, but also hear the difference with each gear shift. Brace yourself to dominate the road like never before with your BMW's newfound power. |
01-22-2024, 10:35 AM | #2 |
Rep 116,006
05-01-2024, 08:10 AM | #3 |
Rep 116,006
