      10-11-2023, 03:34 PM   #1
wilkr1
Drives: 2011 M3 Sedan JB
2011 M3 Sedan rear diff leak
Whats up fellow enthusiasts. Any one had differential leak repair by shop?
I have leak and was quoted 2400 for leak repair. Is that right?
Located Atlanta GA, anyone recommend a shop with reasonable rates? Thanks
      10-11-2023, 05:52 PM   #2
greyspoke
greyspoke's Avatar
Drives: 2010 E92 M3 DCT - Space Grey
I had a pinion seal leak causing the differential to leak. It was about $1200 to replace the seal and flush the differential at the dealership.
      10-12-2023, 07:12 PM   #3
RocketyMan
RocketyMan's Avatar
2008 BMW M3 E93  [10.00]
Wow! That's highway robbery! There are tons of threads on this to DIY--if you're mechanically inclined. Needless to say, it didn't cost me nowhere near the amounts posted above...even on my own time and materials.
Most likely, I'd wager it's a pinion leak, too.
https://www.m3post.com/forums/showthread.php?t=2018581
2008 BMW M3 E93 MT
R135
..246
tigermack474.50
      10-13-2023, 06:27 PM   #4
tigermack
OPN DIFF
tigermack's Avatar
Hong Kong
475
Drives: 10' E90 M3 6MT LB
2010 M3  [0.00]
1995 BMW e36 325i  [7.91]
2006 BMW e90 330i  [8.34]
All the seals/bearings can be installed just by a basic bench press. That's over $1000 for labor is insane.
'10 LB E90 slicktop/speed cloth/6MT
ex. '06 330i 6MT & '10 n54 6MT Msport
Autocross vids https://www.youtube.com/user/tigermack
https://www.instagram.com/tigermack
      10-25-2023, 04:48 AM   #5
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
a rebuilt diff from dan, diffsonline, is $1600 after the core charge. you can change the diff in this car in under two hours. find a new shop.
G-Power Supercharged
      10-30-2023, 09:06 AM   #6
Theodore2
$2,400 is too much, even with a high labor rate. The job is kind of a PIA, as posted above $1,200 seems reasonable for dealer pricing and obviously less at an independent shop. Check out this DIY here to see what is required of the shop that does the work.
      12-18-2023, 09:27 PM   #7
ksc
Drives: e92 m3
Just did this DIY and it was pretty easy. Also replaced all 3 wear and tears for the driveshaft while I had it off (guibo, center support bearing, cv joint). Took a few days total but it was worth it. Didn't touch the axles of the diff, just replaced the pinion seal.
CSBM52722.50
