      10-26-2023, 12:18 AM   #1
charliev68
charliev68's Avatar
204
Drives: bmw m3
Head Studs
Any cons of running head studs on the S65 engine? Is it an overkill?
      11-13-2023, 12:22 AM   #2
danvitmon
Drives: 2008 E90 M3 6spd
The factory stuff is proven and is 100% reliable. There is a guy on the east coast that runs a race car rental business and his E92 M3 had over 70k track miles until the head gasket let go ONLY because his original water pump had broken and didn't flow coolant. Unless you're going with an insane amount of boost, you will be fine. Even the supercharged cars run factory bolts/head gaskets.
You could ask Gintani what they did for their twin turbo builds.
      11-13-2023, 10:30 AM   #3
charliev68
charliev68's Avatar
204
Drives: bmw m3
Would it be easier on the block threads, using the studs instead of bolts?
      11-16-2023, 04:33 AM   #4
danvitmon
Unless you plan on removing the heads multiple times, it doesn't matter. Use new bolts and you'll be ok. I have used the same S52 block with 6 different head combos, all with new head bolts. No issues.
      11-16-2023, 11:12 AM   #5
charliev68
charliev68's Avatar
204
Drives: bmw m3
Yeah. The S52 is an iron block, the threads are super strong
      11-16-2023, 04:45 PM   #6
spammysammich
spammysammich's Avatar
1584
2009 BMW M3  [10.00]
I feel like so few of us have pulled heads off these cars that you may have to ask deansbimmer or maybe amrazm about something this specific. Wish I had a solid answer for you.
      11-16-2023, 04:50 PM   #7
charliev68
charliev68's Avatar
204
Drives: bmw m3
Tried asking Mporium, no response yet.
      02-07-2024, 10:02 AM   #8
Theodore
Theodore's Avatar
Drives: 2011.5 E92 M3
This discussion reminds me of this video. I suspect the same principle applies to the S65:
https://www.youtube.com/shorts/pySyCI1lRq8
What I Wish I Knew When I First Bought My E9X M3 Can Be Found Here
E9X M3 Exact Original Equipment (OE) Equivalent Parts Can Be Found Here
E9X M3 Common Torque Specs Can Be Found Here
E9X M3 "Factory" Tools Can Be Found Here
      02-07-2024, 12:12 PM   #9
charliev68
charliev68's Avatar
204
Drives: bmw m3
He’s one of the main reasons why I am hesitant on running studs. He knows what he’s talking about
      02-09-2024, 05:22 AM   #10
amrazM
mTekMods
amrazM's Avatar
Drives: like a granny.
s52s pull out the studs out of the block when you turn things up.. anyways, I am running more than 7lbs of boost on stock head bolts and never pushed coolant.
G-Power Supercharged
