F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > F32 Pure turbo 750 logs low boost
ARMA SPEED
      04-10-2024, 08:10 PM   #1
dannynonnom
dannynonnom's Avatar
Drives: bmw 435i
This is a log I have taken while doing a single gear pull, and a multiple gear pull, my tuner is RK Tunes
My mods are pure turbo 750, eu5 injectors, lpfp stage 3 and hpfp stage 2
no port injection, no lift kit, running e50 blend
https://bootmod3.net/log?id=6606dd00cf2c9b4d4d4ab2b3 (WOT 1 gear)
https://bootmod3.net/log?id=6617267b92299c13f8c1ce95 (WOT 3 gears)
I want to get to 600whp, so this is just the start, let me know if anyone has experience with the pure 750 on an n55!
      04-11-2024, 05:36 AM   #2
LA1Z24
Drives: 2014 435i M Sport
Are you doing these tunes local with RK? I'm on the next block over Bell
From what I've seen, this turbo doesn't perform all that well unfortunately.
      04-11-2024, 11:30 AM   #3
Slumped335
Drives: BMW 335i
  [0.00]
What’s wrong with the Pure 750? Sorry i haven’t been keeping up with Pure.
      04-11-2024, 12:07 PM   #4
LA1Z24
I dont think there's been a single dyno sheet posted FOR THIS PARTICULAR turbo, that makes anything north of 500whp with ethanol.
Where as the PS2 with ethanol is close to 600whp on a bunch of setups
      04-12-2024, 09:28 PM   #5
5w20
@_sunbish
5w20's Avatar
293
Drives: Bmw 435i & 340i
You should venture out into the n55 fb group. Been a handful that have made over 600 recently.
As for the PS2, I’d take those 600 numbers with a grain of salt. I bet those are inflated dynos, because actual timed performance numbers are underwhelming for the PS2.
You can can skew a dyno number, but I’ve yet to find someone who can skew time.
'14 435i RWD - BM3 stage 2+ E30/bolt ons/stock turbo/full drag pack -- [10.9@125].....60 to 130 - 8.5
'16 340i RWD - BM3 stage 2+ E50/bolt ons/stock turbo/full drag pack -- [10.2@131]......60 to 130 - 7.5
harkes1090.00
      04-13-2024, 09:43 AM   #6
n55david
Check out my Youtube @n55david!
n55david's Avatar
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive  [0.00]
2015 X3 x35i  [0.00]
2015 335i xdrive  [0.00]
Yeah there are quite a few now fyi
2017 m240i xDrive 10.67@132.32mph w/bm3
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD
2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots
IG: @n55david For pics and updates!
Youtube: @ n55david For videos or Racing etc
      04-20-2024, 02:25 AM   #7
VGSON
VGSON's Avatar
Drives: F87 OGM2
your tuner hasn't turned it up yet since you're just starting out...Learn to read logs. You're at 20ish psi and at like 80's%wastegateduty cycle. Your load target is still under 200 as well..Timing isn't above 10deg....Yeah, you're tune is very safe and hasn't been revised much yet. Takes time, be patient.
Im getting towards the finish line with mine. Currently at 25psi on e60 with low 90's wgdc. My load target is around 250 and timing is closer to 15deg...This turbo can do 30psi. I would back your Emix down to e30 to give your fuel system a break until the tuner tells you to add more E. FYI. I'm floating around high 6's 60-130 currently, manually shifting twice and no antilag/brakeboost. We aint done, its got low 6's in it. This is in a M2...Another guy on here hit about the same #'s in a 5 series auto during dead of summer. He was around 650+ wheel. Lookup inhouse performance.
      04-20-2024, 04:26 AM   #8
harkes
harkes's Avatar
China
1090
Drives: M135i, E39 M5, NSX and AE86
This �� Check some 100-200 times and compare them to other factory cars doing some times at similar weight. A GT3 does 100-200 in 7.5 with 510 crank HP...
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China)
f30post
