BPM
      07-24-2014, 12:32 AM   #1
nightwing
Drives: M3 E92
Horn issue
Hi folks-
somehow my horn went out. i hear a click click sound when i push my horn on my e92 M3 but no honk. i checked the fuses and they aren't blown. any other thoughts? i tried to search through forums but i can't seem to find an answer. i'm out of warranty now, sadly.
could it be the relay? or maybe a connection in the steering wheel? any insight would be great! thanks!
      07-24-2014, 01:23 AM   #2
KrazyM3
Drives: 2008 AW M3
It could be the relay or the horn itself. If you can switch the horn relay with something similar to rule out the relay. If the horn itself still does not work unplug the horn and use a test light to see if you actually get 12v at the plug when the horn is pushed. Or you can manually power the horn to see if it works.
      07-24-2014, 01:52 AM   #3
nightwing
Drives: M3 E92
The relays are behind the fuse box? I think i should try that.
If that doesn't work, how do I go about unplugging the horn? Not sure where it's located at...
Thanks!
      12-07-2018, 07:09 PM   #4
hawaiiM3
Drives: 2009 e92 m3
Did anybody find a solution to this issue yet? Where is the horn relay located?
