03-26-2019, 10:43 PM | #1 |
Rep 1
Hi everyone im looking to buy avant garde 359 or apex arc 8, after my research on the forum i found that the best fitment for the359 would be 19 x9 18 and
19x10 25? I want to have a flush /aggresive look than my stock wheels. Also which tire do you recommand me ? I can spend 4000$ Canadian, i live in Québec So if you can recommand me a shop in Montréal it would be great or a good dealer (I speak french) Last edited by Joelg; 03-26-2019 at 10:50 PM.. |
03-29-2019, 02:42 PM | #2 |
Rep 2,650
Appreciate your interest. Give Julien Pichette at JRP a call. JRP is our largest Canadian dealer, and he speaks French
In regards to a 19" staggered fitment, we would suggest the following three options: Option 1: Same specs as the OEM M3 ZCP/GTS Wheels F:19x9" ET30 - 255/35-19 (or 245/35-19) R:19x10" ET25 - 275/35-18 (or 285/30-19) Option 2: More aggressive/flush fitment F: 19x9.5" ET22 - 275/30-19 (or 265/30-19) R: 19x10.5" ET22 - 295/30-19 (or 285/30-19) Option 3: Most aggressive (Similar to option 2 only the front wheels are wider) F: 19x10" ET25 - 275/30-19 R: 19x10.5" ET22 - 295/30-19 (or 285/30-19) * Depending on your ride height and the brand of tire you go with, 295's out back may require negative camber and/or light fender rolling. On car photography EC-7 Design F: 19x9.5" ET22 - 265/30-19 R: 19x10.5" ET22 - 295/30-19 EC-7 Design F: 19x10" ET25 - 265/30-19 R: 19x10.5" ET22 - 285/30-19 ARC-8 Design F: 19x9.5" ET22 - 265/30-19 R: 19x10.5" ET22 - 295/30-19 ARC-8 Design: F&R: 19x10" ET25 - 275/30-19 * 12mm spacers in the rear for a more flush fitment - Ryan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 03-30-2019 at 12:02 AM.. |
12-28-2023, 02:13 PM | #4 |
Rep 3
Best Rim Size for E92 or E93
I found that 19x10 in the front and 19x11 rear take the handling to another level. The only negative is that you must replace the back tires every year and the front every other year.
12-29-2023, 02:45 AM | #5 |
Rep 5,548
12-31-2023, 01:43 PM | #6 |
Rep 1,048
12-31-2023, 02:20 PM | #7 | |
Rep 5,548
I have a 19x11et42 from my f82 m4 that I’d like to run on my e92 m3 and I’m trying to find the correct spacer thickness. I’ve found a range of ETs between 28-34 (1st time hearing et25) but unfortunately not enough pictures showing how the setups fit. I’m currently running 18x10et17 with 285/35 with -1.8 deg camber and it could still run a lower ET with the same camber. Just trying to find the correct frontspacing and especially rearspacing (don’t want to rub fuel filler neck) for an 11” wide wheel. |
12-31-2023, 02:35 PM | #8 | |
Rep 4,107
You can run the 19x11 et25 with stock camber, always depends on the tire size. |
12-31-2023, 02:39 PM | #9 |
Rep 5,548
12-31-2023, 04:50 PM | #10 | |
Rep 4,107
https://www.instagram.com/euro.*****...VkODRmOTdmMw== Google euro c o n n e x |
12-31-2023, 05:01 PM | #12 | |
Rep 5,548
12-31-2023, 09:19 PM | #13 | |
Rep 1,048
There is a very slight amount of rubbing that occurs initially on the nub between the bumper and fender, but it will self clear. Again- it is very slight. |
12-31-2023, 10:14 PM | #15 | |
Rep 5,548
12-31-2023, 10:27 PM | #16 | |
Rep 1,048
There's going to be an option for custom offsets for m359s that I cant quite discuss yet. Will post more info next month. |
12-31-2023, 10:35 PM | #17 | |
Rep 5,548
