  TireRack
      10-05-2023, 10:50 AM   #1
M3atman
M3atman's Avatar
69
Drives: 2009 E92 M3
BBS LM-R (19in) fit with AP Racing BBK?
I'm currently running the Essex AP Racing BBK CP9561 caliper/380mm disc
Does anyone know if the Front 19x9.5, ET25 BBS LM-Rs will clear this bbk?
Before I pull the trigger i'm hoping to confirm fitment. I reached out to Essex and they said they "don't know" as LMRs are not on their confirmed fitment list.
Pics would be great too if you got em. TIA
TTFS Tune | DINAN Exhaust | Bimmerworld Xpipe | OHLINS Coilovers | Challenge Carbon Trunk | Eventuri Intake | APEX Wheels | AP Racing BBK | Turner Monoball
      12-06-2023, 01:50 PM   #2
M3SQRD
M3SQRD's Avatar
2164
Drives: E92 M3,G20 330ix,F22 240iX,F82
Essex has a fitment template you can cutout and verify whether the wheel profile clears the brake template. It takes < 5-10 min to check the fitment. The CP9561 caliper is definitely designed for 19” or larger diameter wheels, diameter wheels. However, at least one forum member was able to get the CP9561/380 mm rotor to work with 18” wheels. The LMR lip size, and, therefore, face offset, will make the fitment more challenging because the CP9561 is a fairly big/wide caliper, making contact with the inner face a possibility.
