F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Confused on new tires (staggered f31)
Studio RSR
      04-29-2024, 11:47 AM   #1
Hammer Werke
Drives: '15 328d Touring
I have a 2015 328d M-sport wagon. It came with the staggered m-sport 18" m400 wheels. I Currently have the stock Pirelli P7 runflats, but I HATE these tires. They are soo stiff, they make the road feel terrible always. Potholes feel like my cars is exploding. On tope of that, they are very fragile! Every single one gets taken out by a sidewall bubble caused by hitting a pothole. But you all probably know how runflats feel. So all my tires have like 5000 miles on them and I just noticed another huge sidewall bubble on the inside of the front tire. So rather than just replacing one again and being stuck in an endless loop of Pirelli P7.... I just want to buy new regular Michelins. I want the Pilot Sport All Season 4s. I'm debating going with a square tire setup but I don't want to get new rims. (Also if anyone wants stock P7 runflats hit me up!)
I have done some reading on here, and I see people recommend the 235/45r18. But can I just buy all 4 of the same size tires and install them on my staggered rims? Or do I definitely have to buy different size tires for the front and rear?
      04-29-2024, 11:55 AM   #2
alohasurftoad
Drives: 440i gran coupe w/mppsk
you can run square 235/45/18 on the OEM staggered 18" rims, however you will not be able to rotate front<--->back. only across the same axle.
      04-29-2024, 11:59 AM   #3
Mkesler75
Drives: BMW f34
Not sure the width of your rear wheels but the advantage of a square setup is you can rotate all wheels without issue and prolong the life of tires. Having staggered wheels prevents you from doing this. So no real advantage to a square setup. Just make sure you use a tire calculator to ensure the tires front vs. rear are within 1% of eachother to prevent issues w xdrive.
      04-29-2024, 12:53 PM   #4
Hammer Werke
Thanks! I think it was some of your previous posts I was reading. Would you recommend going with 235's all around or should I just keep the staggered OEM tire size but ditch the runflats. My car is just a stock Drive wagon, stock ride height etc. Mainly I would like some improved ride quality.
      04-29-2024, 02:23 PM   #5
alohasurftoad
235/45/18 will fill the fenderwell better and reduce gap if you are not lowered. however since the F31 has a heavy rear, i'd prolly just stay with OEM 225/45/18+255/40/18. just switching from the run-flats will provide a noticeable improvement in ride and noise comfort you are seeking.
right now Costco has michelins with discount. they may approve non-runflats if you say you'll have a contingency plan, such as plug/kit+air inflator+etc.
      04-29-2024, 07:04 PM   #6
jmanB45
jmanB45's Avatar
Drives: 2018 BMW 330iX Sedan
I'm with aloha, stay with the stock staggered sizes of 225/45/18+255/40/18 since you have staggered wheels. If comfort is a priority, look at the Continental DWS 06+ instead of Michelin.
      04-30-2024, 12:04 PM   #7
Hammer Werke
Thanks! I checked out Costco It looks like it's about $100 cheaper than tirerack. Now I have to find a tire patch kit. I see there are some oem M3, M4 ones on eBay which are cool. Do you guys carry a jack too? The bmw e60 jack looks ok. I wish there was an OEM f31 jack that fit inside the rear cargo area perfectly lol
      04-30-2024, 12:26 PM   #8
alohasurftoad
i made up my own emergency/tire kit comprised of a 2-ton scissors jack, 18" breaker bar with 17mm deep six-point socket, 12v air inflator, slime tire plug kit, red led flashing puck, etc.
danb19791988.00
f30post
