04-27-2024, 05:52 PM | #1 |
Rep 7
Catless DP vs Catted DP
Looking to get a DP for my 2019 440i, what are some of the pros and cons between the catless/catted downpipes? Or is there virtually no performance difference? New to all this and appreciate any input
04-28-2024, 10:03 AM | #2 | |
Rep 4,924
Catted (high flow): Good ones won't trigger the CEL, and have marginally less performance than catless. Stick to catted downpipes with the 4" catalyst vs those bragging 5" on a 4" downpipe. The 5" versions will give the CEL, and sound horrible (boomy raspy sound). |
04-28-2024, 10:38 AM | #3 |
Rep 84
Also...
I would add that it depends on your location. If you have emissions testing, you probably would need to research the catted downpipe brand that're you're thinking of too... Also, your future goals may impact this choice... I went catless for my pending turbo upgrade. I want the best possible flow for the increase cfm of the new turbo. My goal is pushing the stock long block to the max. Our engines are nothing more than a high-powered air pumps. Anything impeding the flow of air through it from start to finish will cause a power loss. Significant loss? Depends on a few factors but for day-to-day driving, you'd probably be ok with catted. |
04-28-2024, 08:17 PM | #4 |
Rep 76
Another thing to consider is what you're doing with your car. I track my car at Homestead Motor Speedway and I went with a high performance downpipe. 3/4 into my run time at the track the internals of the cat dislodged and clogged due to conditions and the constant driving hard. Maybe I had a bad batch, but I decided to go catless from then on. The smell people complain about maybe only happens at start up and isn't really that noticeable. At least to me.
Dom147102.50 |
04-29-2024, 11:05 AM | #5 |
Rep 191,453
power gains is the same on stock turbo
Catless has a louder tone, but also raspier Catted has a deeper sound I personally prefer the catted sound Catless has a fuel smell Catted does not
Check out our current sale by clicking on this link!
https://x-ph.com/sale/ Phone number 702-494-9435 |
alohasurftoad3132.00 |
04-29-2024, 06:00 PM | #6 |
Rep 111
Before going catless I thought it was gonna be something I wouldn't really mind. But after actually going months catless, I can't stand the smell. Being in someone else's car temporarily wasn't that bad, but dealing with it daily is horrible (for me)
04-29-2024, 06:39 PM | #8 |
Rep 2,963
I've been catless since 2016-17 and don't smell anything. My wife smells like a bloodhound and can tell if I lit a candle on the other side of the house and she's never complained about the smell either.
2015 335i Msport/6 JB4/EWG/E30/VRSF DP/ER CP/ VRSF Race Exhaust/ Injen Intake/Verde Axis 19x8.5/9.5 245/35/275/30 Conti Extreme CS/ H&R Sports / Motorsport Hardware Stud Conversion
04-29-2024, 07:01 PM | #9 | |
Rep 4,380
Although they may not propagate a CEL, it shouldn't be confused with passing emissions tests which vary from state to state |
mobbinthesteez22.50 |
04-29-2024, 09:52 PM | #10 |
Rep 84
Same I can't smell a thing!
...I mean, I hate to ask... But did you guys tighten down the clamps tight enough? As for the raspy tone... I only have that when the exhaust flaps are open and I don't a load on the engine (like revving in neutral or something), otherwise, driving, and under boost, it sounds great. This is with stock exhaust from the downpipe back... |
04-30-2024, 10:34 AM | #11 | |
Rep 191,453
Active Autowerke is the most proven and comes with a no CEL guarantee (it use GESI EPA approved cats) Fabspeed use HJS cats which are excellent as well and wont trigger the check engine light the CG has a good history with CEL but does not come with any guarantee and they do not disclose which cats they use
mobbinthesteez22.50 BlakeBehrens1.50 |
05-01-2024, 07:24 AM | #12 | |
Rep 4,924
As for the raspy note, just have someone take your car and do a part throttle drive by. It has a tinny / raspy note and it's noticeable. |
05-01-2024, 08:26 AM | #13 | |
Rep 228
It doesn't really bother me though. I'm on catless dp but stock midpipe and m performance muffler and imo it sounds perfect. Under load sounds kinda loud and bass-y (only so slightly raspy, but I guess it's subjective) and normal driving it's not over the top, and constant speed I'd say it doesn't draw any more attention than a completely stock exhaust would.
M140i - MHD Stage 2+ E40 - XHP Stage 3 - Catless DP - TU HPFP - MP LSD - MP Exhaust - Endless ME20 brakepads w/ Castrol SRF fluid - Bilstein B12 - Millway solid rear subframe bushings - Goodyear Eagle F1 SuperSport
alohasurftoad3132.00 Wires1664.50 |
05-01-2024, 11:21 AM | #14 | |
Rep 191,453
Yes its definitely there and noticeable. While some might not find it bothersome but to say they can even smell it is surprising
05-01-2024, 08:11 PM | #15 |
Rep 84
My bad... 🤷🏻
I'm not saying it's not there... I'm saying I don't smell it while I'm in the car, windows down. Even sitting at a stop light... If I get out of the car, walk to the back, I can smell it... If I bend over a bit and put my face closer to the exhaust, I can smell it. I had a friend rev it in neutral, I could smell it... But I can't when I'm in my car. It's been rather warm these last few weeks so I ride with the windows down (I like hearing my turbo.. sadly, I miss old school BOV noises... Sigh.. I digress), but I just can't smell it in my car. Sorry... Not sure what to tell everyone. I guess I'm broken. Lucky me I guess... |
05-05-2024, 07:52 AM | #16 |
Rep 4,924
It's because you have your head out the window like a dog smelling the flowers driving at mach 200. What everyone is talking about is a loooonnnngg way behind you. Rest of us just needs to drive faster!
05-06-2024, 12:32 PM | #18 |
Rep 191,453
05-06-2024, 06:26 PM | #19 |
Rep 6
Catless versus high flow DP?
New guy here. I went with catless and I’d agree they do smell a bit but not enough to change my mind. However, the raspy tinny sound when you first start up bothers me, so…. Not sure if I’m going back to stock or try a high flow cat dp. Any recommendations for a good, but affordable high flow cat dp?
Cheers, Bill |
05-07-2024, 11:11 AM | #20 | |
Rep 191,453
if CEL is an issue, get the active autowerke
