Thread closed to new replies
185VIEWS
0REPLIES
05/08/2014LAST POST
Here at P1 Motorcars we would like to offer you Modesta BC-05 – “Advanced Water-repellent Glass Coating”
Modesta BC-05 is a unique glass coating based on a three-dimensional molecular frame. It forms a highly durable clear hard glass layer on automotive paints. BC-05 produces a deep shine and helps to protect the paint from all kinds of damage including wash-induced damages, scratches, oxidation, sap, watermarks, salts and acids. It's strong water-repellent properties also promote the self-cleaning effects.
Used stand-alone as a sealant, BC-05 produces an unique kind of gloss called the "candy-like" gloss. If combined with the P-01A primer this effect is even deeper as the layers of both products are combined to a single coat. The coating also reduces drag by 5 km/h compared to regular paint at speeds over 60 km/h (drag coefficient: -0.02). It can be applied even to the most advanced and sophisticated paints, such as Nissan Scratch Shield, Lexus' self-restoring coat and Mercedes ceramic paint.
Character
Anti-fouling property - As the dirt and grime does not adhere, it is easily removed by rinsing with water (both oil and water based fouling).
Very High water repelling efficiency - Not present in conventional waxes.
Scratch resistance- It excels in abrasion-proof nature and wear resistance. Physical membrane protects paint work from minor car wash scratches.
Heat resistance - Hardened Modesta BC-05 doesn’t burn and will not soften when exposed to high temperatures, this prevents dirt and grime from embedding into the coating.
Gloss - Modesta BC-05 produces a beautiful glass-like shine with extreme clarity.
Weather resistance - The paint work is protected from environmental factors such as ultraviolet rays and acid rain.
Chemical resistant - Deterioration of the paint by the corrosive substances is prevented.
Adhesiveness - Modesta BC-05 forms a strong bond to the paintwork at the room temperature, this ensures long-term durability.
No environmental pollution - As it is a thin film of inorganic coating, there is almost no environmental pollution.
Here are some results
Image hosted on: i1130.photobucket.com
