7,6 kVIEWS
20REPLIES
5APPRECIATES
07/11/2023LAST POST
Cet avertissement est une douleur et commence à monter lorsque le niveau d'essence atteint 1/4 gauche. qui est plus de 100kms ce n'est pas le point.
Y a-t-il un moyen de faire disparaître cela ???
Ou mieux encore, réduisez l'avertissement à quelque chose de plus raisonnable. :mad0260:
You can reduce this by coding/programming...
Spot on ! :thumbsup:
All of the non-m E9x are set to 1/8th. Can be coded to 1/8th as stated above.
I decided against it because in my real world application i'm at ~50mi at quarter tank. Gives me enough notice to not run directly to a gas tank. ~25-30 miles seemed too low once I thought about it. Just giving my 2 cents =)
The Carly app lets you do the coding from your phone... easy peasy! :thumbsup:
Does anyone know the module/code line to change this via INPA.etc ?? Mine sh*ts me also.
KOMBI - C08_TANK_SCHWELLE_RESERVE found it :)
wert_01 for 1/8th
wert_02 for 1/6th
wert_04 for 1/4
Remember the issue if you change to a shorter warning is that you may be far from a refill. I would rather be reminded than get afflicted by range anxiety but thats just me :-)
+1
I rarely let the petrol get that low anyway believing that it's better to have more than less...
Same, but I also know where I'm going and how much fuel I'll use doing so and where there are servos :)
Where do I find out more about this Carly App ?
Nah - it keeps pinging the bell all the time which is annoying and take up the top line of the display. My car doesnt really leave the CBD so there is always a petrol station around.....
In saying that, I have been on 0 kms three times.........
The internet is your friend.... :-) you can buy the app through the App Store and then you need to buy an OBDII wifi dongle through their website. I can show you mine at work over the weekend if you around and want to try before you buy...
Goodnight sweet fuel pump
Carly is your cheapest solution. Plus you can do
Other codings with it.
sounds good
Drop me a PM re your movements over the weekend or join us early Sunday for a wee drive! :D
I didn't think about it, but I know on other cars in the past, it was suggested to keep enough fuel in the tank for cooling the pump. This was along time ago (and I believe saab), but not sure if it was the same on the m's.
That being said 1/4 tank is dangerzone on miles for me, but plenty of liquid volume.
I've gotten down to ~25mi to empty twice at lowest. My E92 328xi hit <5 miles probably a half dozen times over the last decade (2007)
never had a fuel pump issue…..
But a good point Dean
I changed mine via the Carly app. It's a nice improvement. I would recommend Carly to anyone. Carly is worth it just get rid of the legal disclaimer on engine start as well as having the car remember the last setting of the engine start stop button. You do however have to factor in a $A80 annual subscription.
alternative is to do it free with BMW coding tools, done all above plus others (e.g. changing non-zcp EDC profile to zcp EDC profile) for free.
