4,8 kVIEWS
3REPLIES
15/09/2024LAST POST
Hello,
So I wanted to give this sub-forum a shot on the issues that I'm having right now.
I'm getting a number of fault codes on my car. I really don't know what it could be (I've taken it to 4 different places and nobody knows what it is).
I. Function Centre, Roof (FZD)
- A669 Front Interior Lights
II. Siren with Tilt Sensor (SINE)
- 9D12 Internal Battery (New)
III. Car Access System (CAS)
- A127 Incorrect signal from engine management (New)
IV. Digital Motor/Diesel Electronics (DME/DDE)
- CDB8 Message (torque request, DKG, 0xB8) faulty, receiver DDE, transmitter EGS/SGM/DKG (New)
- CD9D Message (Transmission data, 0xBA) faulty, receiver DME, transmitter EGS/SMG/DKG (New)
- CDB4 Message (transmission data, 0x3B1) faulty, receiver DME, transmitter EGS/SMG/DKG (New)
- CD9E Message (transmission data 2, 0x1A2) faulty, receiver DDE, transmitter EGS/SGM/DKG (New)
V. Electronic Transmission Management (EGS)
- 5129 electr. fault at parking-lot magnet (energizing not possible) (New)
- CF27 Message (operation, gearbox selector switch 2, LIN) from GWS (New
VI. Gear Selector Switch (GWS)
- E094 No message...
Any help is appreciated. I'm really at the end of the line with this car.
Just a note, the transmission fluid was changed just recently.
Hi, did you get to the bottom of this?
Keen you find out if you are able to fix this..
I am also having same errors and cannot change gears at all, DCT..
CDB8
CD9D
CDB4
CD9E
CDB8
CD9D
CDB4
CD9E
do you have the gts flash?
Darkne55 a écrit
Salut, tu es allé au fond de tout ça ?
Découvre si tu es capable de réparer ça.
J'ai aussi les mêmes erreurs et je ne peux pas changer de vitesse du tout, DCT.
CDB8
CD9D
CDB4
CD9E
Hey,
Je sais que ce fil de discussion est vieux (j'ai oublié à la fois ce compte et mon adresse e-mail associée, alors désolé).
Avez-vous réussi à résoudre votre problème ?
Je le soupçonne fortement, mais pour quiconque à l’avenir regarde à travers ce fil, mon problème a fini par être un mauvais point de départ principal pour la voiture. Cela a fini par résoudre le problème.
