12,8 kVIEWS
51REPLIES
49APPRECIATES
19/11/2020LAST POST
La température du moteur S65 devient extrêmement chaude même sur les circuits à grande vitesse comme Suzuka, ne peut pas imaginer ce que la température des roulements ressemblerait à faire 1-5 mph avec peu de refroidissement. Celui-ci était une chaîne VANOS mais ne peut pas imaginer que l'état de roulement serait bon avec cet usage non plus.
pbonsalb a écrit
Colinv6 a écrit
En tant que nouveau propriétaire de 2 semaines, ce fil me remplit d'effroi. :(
Donc, non seulement je dois considérer les RB mais même si je change ceux-ci, le roulement principal peut aller aussi?!
Très rare par rapport à la défaillance du roulement de tige. Et trop cher pour changer préventivement si vous devez payer du travail. Pas la peine de s'inquiéter.
Alors, qu'est-ce qui le provoque et comment est-il empêché? Ce truc me rend nerveux.
threads like this make me feel better for doing my RBs right after I purchased the car, not doing donuts, or revving the engine while cold, or drifting the damn thing lol
230k Kms, no issues ever! Change my rod bearing at 160k kms for the hell of it. They came out pristine btw.
Pristine at 160k km? Did you ever share some pics??
MShift wrote
I religiously took care to avoid all those things and I don't have a supercharger. There was no reason at all for this. I've owned the car for 4 years since it had 12k miles... unless previous owner absolutely beat the crap out of it, which it didn't look like since the engine, exterior and interior were pristine, then there's no reason for this other than a premature RB failure.
Edit: stock redline.
Sorry to hear. But you ponder, how many of those miles were track?
I was looking to purchase one 10K miles, pristine inside and out. Owner claimed no person had ever been in the back seat. However, given the car he was replacing it with was a Porche GT3... I'd say more than likely his had seen track time.
You have to ask yourself. How much of the engines life has likely been spent above 5000rpm.
The M3 that I did end up buying, the M-drive came programmed on Lv 5. That lets the engine hit 8000rpm routinely before upshifting (upon full-throttle). IMO I see no need for that, Lv 3 still gets you to 7000rpm that's plenty power/noise to enjoy without unnecessary motor/oil stress. So for me, that's a warning sign and am all prepped to do rod and main bearing replacement in near future.
That's garbage. I'm not seeing engines fail more often on cars that are tracked. If you're worried about abuse it would be high revs when the engine is cold, but you'll never know unless you're the only person who ever drove the car, and the bearings could still fail because there is a design flaw.
Furthermore I think the point of the engineering if this car is to rev it all the way out, because that's where the power is. They could have made a low revving V8 but they didn't. There's plenty of turbo cars that give you nothing more when you rev them out and are more fun in the mid range, but that's not the s65. I mean it's your money and your choice on how to drive the car you buy, but I feel you are misunderstanding this platform and what is and isn't harmful to it.
bmwpower603 wrote
@Assimilator1: Count it!
Thanks :), but unfortunately your tag is broken and so I didn't get a notification.
I don't know how to tag either, can someone tell us?
Btw folks, feel free to tag me if ...... when :( the next engine failure happens, I rarely look through all the new threads but I do get notifications (hmm, I need to activate email notification[edit]I had anyway, but it doesn't work!).
SYT_Shadow wrote
It is in the S65 technical information.
Meanwhile, Vettes for example have had dry sumps for many years. In the C8 development interviews the Jueutcher guy (hard name I can't spell) said they had improved their dry sump system since the C7 gen and this time they had lost many fewer engines. He quoted their lateral G handling for the C8 gen at 1.25g. Really makes me wonder what the C7 had.
'Dry sump' is yet another word in the long list of words that mean very little. Right along 'purpose built sports car'. It checks a box but provides very little actual information.
I would think the G pulled at the front end of the car during a donut is very small anyway, sometimes 1 front wheel is near enough stationary! ;)
Oh? Can you show us some photos? If that's the case then I'll add you to the list of (so far) 2 OEM sets out of 525 which have come out pristine!
But often people mistake the moderate wear on the LCI bearings as pristine, when they're not.
