16,6 kVIEWS
12REPLIES
18APPRECIATES
13/08/2022LAST POST
Here's the latest iteration of our friend, Claudio's E90 M3 track car we've been building for him over the last few years. Also attached some photos of the goodies in and under the car that can't be appreciated on the ground :)
Mod List:
Forgeline GS1R Wheels 18x10.5 square
StopTech Trophy BBK
Ohlins Dedicated Track Coilovers
Burkhart brake cooling
ESS Tune
Alpine GTS DCT software
WPC rod bearings w/ APR bolts
BimmerWorld P/S reservoir
Rogue Engineering Stud Kit
Challenge E90 diffuser
Aim Solo 2
Aim Solo Smarty Cam
Custom Aim solo center console bezel mount
OMP WRC-R seats
Planted floor mounts
Schroth 6pt harnesses
Brey Krause harness mounts
Rennscot harness supports
M Factory Carbon Fiber Driveshaft
Akrapovic Evolution exhaust
Fall Line Motorsports Half Cage paint matched by IND
Interlagos blue side markers by IND
Diffsonline 3.64 LSD differential w/ Motul FF track fluid
Eventuri plenum intake
Hardmotorsport trunk panel replacement
H&R sway bars
SPL Parts Front lower control arms
SPL Parts Front tension rods
SPL Parts Front tie rod ends
SPL Parts Front sway bar end links
SPL Parts Rear sway bar end links
SPL Parts Rear toe arms with eccentric lockout kits
SPL Parts Rear upper arm links
Turner Motorsports Solid Rear Subframe Bushing Kit
Do88 DCT Oil Coolerwith carbon air duct
Do88 Power Steering Oil Cooler
Do88 Radiator
CSF oil cooler
Trackspec hood luvers
Mashimarho fender vents
APR front splitter
Professional Awesome quick release chassis mounts
Professional Awesome splitter struts
Professional Awesome front splitter diffuser pieces
BimmerWorld front canards
Status Gruppe front lip
APR 67" air foil
Hard Motorsport chassis mounted wing uprights
truly love this car and how much attention to detail you guys put into the cars that come through the shop. I really appreciate you guys help on my SS E90. If you don't mind me asking what size wheels are on this car?
Awesome build, as always.
There's a lot of little things hidden around the car when you walk up to it. We ran the Forgelines in 18x10.5 et22 square.
thanks!
Incredible work as always ACM team!
Incredible as usual.
Amazing build. Would you please list the mods? Especially interested in the suspension parts and cooling. Thanks
Does the wing hit the glass when you open the trunk fully?
Thanks!
List of mods please. This is an amazing build. :)
Thanks!
Yes it does
Mod list added to the original post. Been building this car for a few years now, so I'm sure there's things I missed, but that should be the bulk of it :)
Thats fuckin sick
Your build is amazing!!! 285/35/18 squared??
Depends what is available with the model tire it's either 275 or 285
