Wow, mon rapport S54 (Z4M) de Blackstone semblait mieux que certains des rapports vus ici, et j'utilisais une huile 5W40...
497 kVIEWS
1,2 kREPLIES
181APPRECIATES
2 d agoLAST POST
J'ai pensé à le faire pendant un moment. Heureusement que j'ai changé tous les 5 km.
Quelqu'un a-t-il envoyé une huile autre que le castrol 10-60 de leur s65?
Surprise ! Les roulements dans mon '08 s'usent! Oh joie ! C'est pour ça que j'aime Blackstone. Ils connaissent leur merde. Et non, je ne le conduis pas trop fort. Juste un blast de canyon.
Et BMW est fou de dire qu'il est acceptable de faire fonctionner l'huile pendant 15 000 miles. Il n'y avait plus d'additif et vous commenciez à gommer les choses bien avant ça.
Try another analysis in 8k miles. Wonder what bmw will say about the bearings. My numbers have been high too.
M3PO wroteThat TBN rating is bizzarre. Although it is also somewhat bizzarre to me that they don't always include the TBN rating. Do you do your own oil changes? If not, you sure the dealer is using the right oil?Surprise! The bearings in my '08 are wearing out! Oh joy! This is why I love Blackstone. They know their shit. And no, I don't drive it too hard. Just one canyon blast.
edit: And BMW is batshit crazy to say that it's okay to run the oil for 15,000 miles. It'd run out of additive and you'd start gumming things up long before that.
Also - who is taking the sample? The dealer or you? Because you need to catch the sample in the middle of the oil draining. If you take it at the end, it could make it look at lot worst than it actually is.
As far as wear goes - there are a number of people that have talked about the redesign on the bearings, although it doesn't seem exactly clear to me what changed. So their could be some issue there.
Running higher octane and/or a less aggressive tune might help as well. No way to tell without logging. If you are getting detonation, that will increase wear on the bearings. What fuel supplier?
Also, you are always letting it warm up fully before romping on it right? Pushing it too hard too soon can definitely cause additional wear.
Sorry you are worried about this...just offering up some suggestions that may help.
Good luck man.
M3PO wroteAMEN..glad you got your mind right..been saying this for yearsAnd BMW is batshit crazy to say that it's okay to run the oil for 15,000 miles. It'd run out of additive and you'd start gumming things up long before that.
tibra1 wroteSo your position is that BMW knowingly destroys their own engines by extending oil change intervals? What is their goal with this strategy?AMEN..glad you got your mind right..been saying this for years
You know his results are out of line with other engines of this type and the same interval of use right?
I dont think I said anything of the kind..just merely staying within a safe margin of error with oil changes interval..the small cost doesnt justify not changing oil more frequently than recommended by BMW
tibra1 wroteSee but your statement implies that it is not safe to follow the recommended interval. Changing it more often certainly won't hurt, I guess except from the perspective of waste, I've just yet to see anyone explain why an engine builder would knowingly put their equipment at risk.I dont think I said anything of the kind..just merely staying within a safe margin of error with oil changes interval..the small cost doesnt justify not changing oil more frequently than recommended by BMW
Did you know that the great Ferrari now has 12,500 mile oil change intervals?
Waste?..Last i checked oil gets recycled? The only waste you are really considering is cost..A $200 oil change vs $thousands in potential repairs..I guess you dont subscribe to preventative maintenance
tibra1 wroteI don't know at what rate oil gets recycled, but it certainly requires energy to do so, so yes there is waste.Waste?..Last i checked oil gets recycled? The only waste you are really considering is cost..A $200 oil change vs $thousands in potential repairs..I guess you dont subscribe to preventative maintenance
My BMW has preventative maintenance, you just don't agree with the interval.
To each their own I guess I dont wan to be a lab rat with BMWs “recommended” intervals..I will err on the side of caution.
Singletrack wroteThis oil was put in by the dealer before I bought it. The PO was "taking it to term" and only changing the oil when it was free (every 15K). I bought the car shortly after the last dealer change and only ran the oil for ~7800. I do my own changes. I think it's the right oil based on Blackstone's measurements. I took the sample myself mid drain. I let it idle until the cold start cycle finishes and then go easy on it until it's fully warmed up. I only use Chevron 91 from a station with separate hoses for each grade.That TBN rating is bizzarre. Although it is also somewhat bizzarre to me that they don't always include the TBN rating. Do you do your own oil changes? If not, you sure the dealer is using the right oil?
Good luck man.
Singletrack wroteBMW only cares that the engine lasts beyond the warranty period plus enough not to provoke any lawsuits. They're not engineering these things to last as long as possible. It's a planned obsolescence sort of thing IMO where they keep you coming back for another one. They'd never meet their bottom line if the cars never wore out and they offered free oil changes that maximized engine lifetime.So your position is that BMW knowingly destroys their own engines by extending oil change intervals? What is their goal with this strategy?
Also, I don't think my results are out of line with other people's experiences based on this thread.
Free oil changes is US only.
Most people buy in and out of luxury cars long before the engine is even approaching any serious age, so I don't see the planned obsolescence argument. Cars are staying on the road longer than ever now.
Your tbn is low and metals are high for the interval IMO. Although in general, UOA's don't speak to the ability of the oil to actually lubricate the engine. 91 octane has a better chance of causing more wear than 12k-15k mile oil changes IMO. Detonation is what beats up the bearings and you will not run the best timing on 91.
Although again, there has been some hearsay that the 08 bearings are even tighter than the 09s, and therefore could wear worse. You also don't know how the previous owner treated the engine.
Here is my latest report at 37,000 miles
Singletrack wroteThat is the opposite. The tighter the clearance the less wear there will be. I have ran a test report on fresh 10w-60, here is the report in case anyone was wondering.Although again, there has been some hearsay that the 08 bearings are even tighter than the 09s, and therefore could wear worse. You also don't know how the previous owner treated the engine.
We have a oil machine at work so it is convenient. I had to block out certain things, sorry.
kawasaki00 wroteEhhhh. Obviously there is a happy medium. Too tight or too loose is going to be a problem. At least one experienced mechanic on this board has given his opinion that the clearance is too tight.That is the opposite. The tighter the clearance the less wear there will be. I have ran a test report on fresh 10w-60, here is the report in case anyone was wondering.
Thanks for the report.
Just got my results back from Blackstone
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2722326#Post2722326
Wow, great thread...
I'm seeing a trend of high lead in these engines. Mine also showed elevated lead content. Going to check again in a few thousand miles and see if it dropped.
damnit I knew I shouldnt have read this thread. Now I'm all scared. You will see my results up here in a couple months
Had my oil tested from Amsoil/Oil Analyzers Inc at 16K + miles (and last oil change was at 1,200 miles) and zero issues. For those who are worried about oiled/cotton gauze filters letting in more silicate, so far so good (I have a MS intake/filter w/ RPI scoops). Will be interesting to have this tested over time. Most dealers are compliant with filling the sample jar at service intervals... apparently quite a few customers ask for it.
Mike -
High lead at what mileage? So far at ~36000 lead in my '08 with no change from the test at ~22k which came up at 5ppm. (been running a test every other change). The next change at 43k will have half a season of pretty frequent autocrossing on it so will be interesting to see if there's a change.
