4,8 kVIEWS
9REPLIES
19/02/2010LAST POST
Ne pas aller, je les mets avec la tige du volant trop NON et ils ne fonctionnent pas en mode normal. De toute façon de mettre cela en place de manière permanente s'il vous plaît.:confused2
Vous avez I-drive ?
With ignition on, go to M settings, then you can select 'key settings' where you can permanently set the shift lights to come on with the current key.
Trier Germany wrote
Do you have I-drive.
Yes I do
Great I will go and try this .Thanks.:cool!:
Is there anyway to permanently set this for those that do NOT have I-drive?
Are the shift lights only for DCT or is it part of an option package? I test drove a 6 speed that didn't have it.
DCT only.
