3,6 kVIEWS
5REPLIES
30/04/2012LAST POST
Il y a du DIY là-dessus ?
Même si c'est vraiment simple, ça serait très rassurant d'avoir une idée de ce que je fais.
L'ordre dans lequel saigner est de partir de la roue la plus éloignée du maître-cylindre puis de travailler votre chemin vers elle.
RR, LR, RF, LR
Est-ce que c'est ce dont vous avez besoin ou... Plus ?
Drifty// wrote
Dumb question: is bleeding the same thing as flush?
In that case, here's a flush DIY:
http://www.m3post.com/forums/showthread.php?t=316236
No, but they're related. Flush means you replace all or nearly all of the fluid, bleeding just means getting the air bubbles out (and probably adding some more fluid as a consequence). You do have to bleed in a flush though, so that DIY should be fine.
From the sounds of it, you're probably off paying a professional to do it.
^good point. Honestly the easiest thing to do is just get a buddy at the track to show you once and then you'll be competent for the next time. If you don't know anybody at the track just approach someone, in my experience people are always eager to help each other work on cars as long as it's not a lot of work.
