y a-t-il des guides de bricolage pour CF Spiltters essayera de les joindre par moi-même
2,3 kVIEWS
7REPLIES
20/05/2013LAST POST
Il a fait un rapide
dans la section DIY et a trouvé quelques fils utiles ..
http://www.m3post.com/forums/showthread.php?t792902&highlightsplitters
http://www.m3post.com/forums/showthread.php?t654068
http://www.m3post.com/forums/showthread.php?t538985&highlightsplitters
dans la section DIY et a trouvé quelques fils utiles ..http://www.m3post.com/forums/showthread.php?t792902&highlightsplitters
Geneatal a écritIl a fait un rapidedans la section DIY et a trouvé quelques fils utiles ..
Merci beaucoup pour ce beau travail !!!
they r very easy to install i did my car last in about 45 minutes last night. you need a drill a 8mm socket and double sided tape.
tony093 wrotecan the double sided tape a specific brandthey r very easy to install i did my car last in about 45 minutes last night. you need a drill a 8mm socket and double sided tape.
i used 3M super strong
If your using 3M make sure and also get the adhesive promoter
JEllis wroteI didn't use adhesive promoter with my 3M tape installation. They're definitely on there...If your using 3M make sure and also get the adhesive promoter
