Nickz95 wroteThese will pair right up to the Pole Position, however if you have the NG version you wont use the side mounts included. These include everything you would need in order to mount up a race seat. I am running these in my M3 with a Sparco seat.I'm keen on these mounts to use for my Recaro Pole Position seats. Just want to confirm these work with them and that the standard seat belt is still usable without needing anything else? Also is there any other possible mounts you would recommend over using these?
46.5KVIEWS
73REPLIES
05-06-2026LAST POST
kevin @ eas wroteNickz95 wroteThese will pair right up to the Pole Position, however if you have the NG version you wont use the side mounts included. These include everything you would need in order to mount up a race seat. I am running these in my M3 with a Sparco seat.I'm keen on these mounts to use for my Recaro Pole Position seats. Just want to confirm these work with them and that the standard seat belt is still usable without needing anything else? Also is there any other possible mounts you would recommend over using these?
kevin @ eas wroteCan you pm me with a shipping quote to 2163, NSW AustraliaNickz95 wroteThese will pair right up to the Pole Position, however if you have the NG version you wont use the side mounts included. These include everything you would need in order to mount up a race seat. I am running these in my M3 with a Sparco seat.I'm keen on these mounts to use for my Recaro Pole Position seats. Just want to confirm these work with them and that the standard seat belt is still usable without needing anything else? Also is there any other possible mounts you would recommend over using these?
Nickz95 wrotePM sentCan you pm me with a shipping quote to 2163, NSW Australia
Can you please let me know if these mounts will work for Cobra Nogaro seats and if so, would I need the standard or wide size? Also, please confirm that the OEM E92 M3 3-point seatbelt receptacle can be installed directly to this mount. Thanks
pogara27 wrotePM sentCan you please let me know if these mounts will work for Cobra Nogaro seats and if so, would I need the standard or wide size? Also, please confirm that the OEM E92 M3 3-point seatbelt receptacle can be installed directly to this mount. Thanks
Do these fit E93 M3’s ?
Adriano917 wroteThey do have the provisions for both the lap belt and the seatbelt receptacle. They will fit, however the e93 the upper seatbelt are fixed to the seat. You would need to run aftermarket harnesses with a cage or roll bar to attach the belts.Do these fit E93 M3’s ?
kevin @ eas wroteWhat would be a good kit (driver & pass) with seats.They do have the provisions for both the lap belt and the seatbelt receptacle. They will fit, however the e93 the upper seatbelt are fixed to the seat. You would need to run aftermarket harnesses with a cage or roll bar to attach the belts.
Macht Schnell clubsport mounts ready to ship
PM today to get yours
Macht Schnell clubsport mount kits back in stock and ready to ship
PMed
Sublivion wroteShipping your clubsport mount out to you today.PMed
Macht Schnell clubsport mount kits in stock and ready to ship
