5.5KVIEWS
0REPLIES
05-26-2022LAST POST
Play your favorite games anywhere with this GAEMS Guardian Pro portable gaming environment. The 24-inch display delivers quality graphics, while the chambered dual speakers have built-in power amps for tuned stereo output. This GAEMS Guardian Pro portable gaming environment includes multiple USB ports to connect your console or charge devices and holds up to 10 lbs. of mounted accessories.
Compatible
- PS4, PS4 Pro, Xbox Series S, Xbox One S, and PC
Features
- 2K Quad HD 2560 x 1440 resolution
Expand your gaming performance in line with the power of your graphics card.
- 9 ms response time
Delivers solid performance for precise gaming and video work.
- 60 Hz refresh rate
Provides smooth video and good refresh rates for everyday use.
- 24" LCD monitor
Uses cold cathode fluorescent lamps to provide even backlighting across the entire screen.
- HDMI input
Allows you to set up DVD players and other AV sources for a clear, high quality audio and video signal.
- 1,000,000:1 contrast ratio
Ensures images are crisp and clear with deep blacks and bright highlights.
- 300 cd/m² brightness
Produces bright images that can clearly be seen even in well-lit rooms.
What's Included
- GAEMS Guardian Pro XP
- HDMI cable
- USB cable
