4.4KVIEWS
8REPLIES
2APPRECIATES
10-01-2022LAST POST
Hey guys,
I decided to tackle the Oil Filter Housing Gasket replacement and so far I can't say it's been a hard job, just takes a while.
Now, I need some help finding various torque numbers. What are the bolts holding the oil filter housing to block torqued to? There are 3 different bolts. Does anyone have a torque pattern as well?
Also, since I had to remove water pump pulley, PS pulley, idler pulley, etc… do I need to replace all those bolts? Can any of these bolts be re-used?
Thank you!!
Look/search in the diy section. 👍🏻
See images
Bmwdoubles_ wrote
See images
Thank you very much! Where would one need to subscribe/pay to in order to get access to such manuals?
Bmwdoubles_ wrote
See images
Do you also happen to have torque pattern for the housing bolts? Thank you!
NiBe wrote
That makes sense that Torque numbers are different, since there are two types of bolts M6 and M8 style. Although there are 6 different part numbers for all of the 10 bolts, they are either M6 or M8!
Thread referenced by Bmwdoubles_ in Oil Filter Housing torque specs 10-03-2023
