Had a pretty loud ticking noise from the engine under load recently. It only appeared above 3000 rpms and followed the rpms. I changed the oil last August, about 3500 miles ago with LM 10w-60. Just changed the oil this morning with RL 10w-60 and after it was up to temp, tried revving again. Same sound. I pushed it a little higher to about 5k and now the ticking is worse and shows up at about 1000 rpms. Do I have a bad hydraulic lifter or is it something else like valve springs? I'm assuming at this point, no additive will help...
Video is up to about 1k rpm. No codes showing, but I haven't driven it since I first heard the noise and parked it.
