3.9KVIEWS
0REPLIES
08-04-2025LAST POST
Ok chaps so the pan roof in my 2006 E91 is busted. The rear panel has corrosion issue in the mechanism and can only be closed by tapping it shut using screwdriver and hammer 😔. I have no were that I can remove to try and repair it. So is there a way I can disconnect the rear panel so just the front main section which still works fine will operate along withe the sunblind which is currently permanently open. Thanks
