792VIEWS
4REPLIES
2APPRECIATES
06-16-2026LAST POST
Hello fam,
Silly quesiton for the group. I did a double to single hump conversion and got the correct bracket and HVAC. it plugged right in but it doesn't seem to want to turn on.
Does coding need to be done or is there something else I am not aware of?
Thanks!
Rubin
former 240 s14 wrote
Hello fam,
Thanks!
Rubin
I didn't need to do any coding to get the HVAC working when I did the same conversion, just plugged everything in and it all just worked. I'm am getting faults when I scan in ISTA for the iDrive controller and a few other related faults that I'm sure with coding I can remove but not quite sure what I need to do.
Weird, good to know. TY!
Found the issue, connector wasn't 100% tight. DUH!
Thanks gang!
Rubin
Nice, hope it wasn't too much of a pain to get back behind there! I had a similar issue recently with the connector for the oil pump on the manual trans. Easy fix!
