It's hard to believe that the HP has nearly doubled in the M3's since the E36. BTW, it looks like the engine output figures are the EU ratings. Like E46 is 343 bhp and E92 is 420 bhp. We all know those figures here Stateside to be 333 and 414 respectively.
330.7KVIEWS
65REPLIES
10APPRECIATES
05-20-2023LAST POST
Greetings,
The second to last document, before the 2010 GTS - states the 2007 E92 coupe (and others) as 420 bhp - so what is it ?
420 or 414 ??
Cheers,
Merlin
420 or 414 ??
Cheers,
Merlin
Merlin_83 wroteEuro cars rated at 420, North America at 414 HP.Greetings,
420 or 414 ??
I'm trying to find if the e92 ever came with Carbon Ceramic brakes. I keep searching and all the turns up are the Brembo upgrades. I couldn't find it on this sheet. Does anyone know if they came from the factory in the US with them, and what year?
Merlin_83 wroteGreetings,
420 or 414 ??
Cheers,
Merlin
Beemdog wroteIts just a different standard/unit of measurement.Euro cars rated at 420, North America at 414 HP.
PS/Metric HP/DIN HP vs Imperial HP/Mechanical HP/SAE HP.
Germany, Japan, Italy use the former. USA & UK use the latter.
Hence 420 / 414.
But the engines are rated for exactly the same output, 309 kilowatts (kW).
In fact, if you do a cross conversion between the different units of measurements, they prove to be identical.
Cruxin wroteNo. M-cars didn't have a CCB option until the F-chassis.I'm trying to find if the e92 ever came with Carbon Ceramic brakes. I keep searching and all the turns up are the Brembo upgrades. I couldn't find it on this sheet. Does anyone know if they came from the factory in the US with them, and what year?
Law wroteSolid post. I have now learned something valuable today. Thank you kindly!Merlin_83 wroteGreetings,
420 or 414 ??
Cheers,
MerlinBeemdog wroteIts just a different standard/unit of measurement.Euro cars rated at 420, North America at 414 HP.
Hence 420 / 414.
Carbon Ceramics... Anyone?
Just hopped back on the forum...still got a 04 Civic and I think I am gonna go with a Subaru WRX for my next car :/ I live in New England and rwd is tricky but one day I hope I can afford an M3, still need to save up for the Subaru
I still have a lot to learn about M3's also.
Thanks!
With so much inaccurate information, I don't think we should be promoting this document. Just take a look at the 4 speed automatic on the e46 and e9x.
dallas06m3 wroteYep. This thread should not be a sticky. It's full of crap and hasn't been corrected.With so much inaccurate information, I don't think we should be promoting this document. Just take a look at the 4 speed automatic on the e46 and e9x.
Richbot wroteQuick question, is there an actual PDF attached to the OP? I only access M3Post from an IPhone, so I'm assuming if there is a PDF then I would need to login from a computer. I do understand from comments that there are many mistakes, just trying to figure out why I'm not seeing a PDF more so than what the content of it is.dallas06m3 wroteYep. This thread should not be a sticky. It's full of crap and hasn't been corrected.With so much inaccurate information, I don't think we should be promoting this document. Just take a look at the 4 speed automatic on the e46 and e9x.
BOOF-M3 wroteYup, there's a 11 page PDF in the first post.Quick question, is there an actual PDF attached to the OP? I only access M3Post from an IPhone, so I'm assuming if there is a PDF then I would need to login from a computer. I do understand from comments that there are many mistakes, just trying to figure out why I'm not seeing a PDF more so than what the content of it is.
jiggz wroteI'll have to log onto a computer then. Thanks Jiggz.BOOF-M3 wroteYup, there's a 11 page PDF in the first post.Quick question, is there an actual PDF attached to the OP? I only access M3Post from an IPhone, so I'm assuming if there is a PDF then I would need to login from a computer. I do understand from comments that there are many mistakes, just trying to figure out why I'm not seeing a PDF more so than what the content of it is.
Richbot wroteYep, that .pdf is still crapYep. This thread should not be a sticky. It's full of crap and hasn't been corrected.
Jason wroteExcellent document! Thank you 🙌🏾Here's a great resource - a PDF containing all the technical specifications for every single M3 model and edition BMW has ever produced. Want to know what the roof load, gear ratios, or suspension type is for a particular M3? It's all in here, plus much more.
BMW AG Presse File Attached:
Hey Guys!
Would you hand me some technical literature, like BMW Group University Technical Training about the S65 Engine?
Jason wroteThis is just what I needed. Thanks for sharing.Here's a great resource - a PDF containing all the technical specifications for every single M3 model and edition BMW has ever produced. Want to know what the roof load, gear ratios, or suspension type is for a particular M3? It's all in here, plus much more.
Hi Guys , new to this forum hoping to get some info. Was trying some new shifters and did not like the look and when I replace the OEM shifters its not changing gears. I removed it a few times cleaned the like the gold connections put it back in and also put the ball bearing back in and I think the correct was as I can move the shifter ok. also the back plastic section that the shifter screws on has a spring that can come out.
Any ideas would be great before I have to buy another one.
Thanks
Chris.
Thanks
Chris.
hello
hey guys , looking for some help with finding pinout for mss60 2011 M3 E90 . much appreciated .
hello
