Sounds odd. Did you do the install or someone else? Was the install and alignment done at the same place?
36.9KVIEWS
26REPLIES
1APPRECIATES
04-20-2015LAST POST
Toe is off left to right in the front. One is turning in, and the other turning out...
Yea the toe looks off.
ConceptE92 wroteI was curious what you found out about this? How did you fix it? I just installed my coil overs and may have a similar issue. I haven't done alignment yet.Hi guys -
Not sure if you would be able to pitch in your opinion but I have already searched online as much as I can and I am really down to my last resource which is this thread I came across.
I purchased the same exact kit for my M3 E92. After the installation was done, the alignment was next and everything was ran to spec. Here are some details:
Left Front:
Camber: -1.7
Caster: 7.5
Toe: .42
Right Front:
Camber: -1.7
Caster: 7.3
Toe: -.24
Left Rear:
Camber: -1.6
Toe: .06
Right Rear:
Camber: -1.7
Toe: -.09
Thrust Angle: -.01
I get in the car and the steering wheel pulls a sharp right just rolling at 5 mph. The alignment is spot on, however I am not sure where to even start to look for issues. Anyone ever had this problem???
thanks in advance,
So you ARE supposed to get bump stops with the kit right? Front AND rear?
I got neither in my package.
