BMW Garage | BMW Meets | Register | Search | Today's Posts | Mark Forums Read |
BMW 3-Series (E90 E92) Forum
Partially Built N54 Engine for Sale -SOLD
| 11-13-2023, 07:49 PM | #1 |
![]() 408
Rep 1,405
Selling partly assembled built N54 engine. PLR Performance Engines have assembled the crank, rods, pistons and head. All other parts required to complete the engine build come with the engine. Price is $12,000 plus freight.
Head The head has been ported, cleaned, valve seats cut, spring tensions checked, holes between the PCV and intake ports have been threaded and plugged for the use of catch can and new valve guide seals installed. The flow results are shown below (bottom) with others (top) for comparison. Standard OEM head bolts have been used. New hydraulic lifters, camshaft ledge bolts and vanos unit bolts are included. Parts for completing the head installation Bottom End Bore size is 84.5mm. JE pistons, Carillo rods and ACL Main and Rod bearings. Above is photo of partially assembled engine still in wrapping from PLR Performance Engines Parts for completing bottom end of engine. Included are new aluminum bolts, crankshaft hub bolt, grip disks for chain gears and gaskets. Oil pump has only done 500km. Last edited by Coupes33; 03-02-2024 at 04:25 AM.. |
| Bookmarks |
| Thread Tools | |
