05-01-2023, 03:01 PM | #1 |
Rep 150
Valved Exhausts in 2023
I am in the market for a valved exhaust and have been browsing all the threads I can find looking at the available systems. However, a lot of the comparison threads are dated and I can't find a good one comparing all of them together. A lot of systems have popped up in the last few years and I wanted a centralized place to compare them.
As a note, I am only going to include prices for the axleback version of each exhaust for easier comparison. I am going to start by listing the exhausts that I believe are all identical, but rebranded: GRWA Performance Exhaust System: Price: $750 (I believe you have to order a sample to get just 1) Valve Type: External Vacuum Box Pros:
Valvetronic Valved Sport Exhaust System (V2): Valvetronic appears to have made a V2 of this exhaust. The call out they went back to a vacuum controller and that they "improved sound quality", but I have no idea what this means. Price: $1999 Valve Type: External Vacuum Box Pros:
Bomiz Valvetronic Axleback for E9x M3: Price: $2200 Valve Type: Electronic Valves Pros:
ARMYTRIX Valvetronic Exhaust System: I am throwing ARMYTRIX in this section based on what I know about them, but I may be wrong here, so please correct me. Price: $3140 Valve Type: External Vacuum Box Pros:
Alright, with the exhausts I believe to all be identical out of the way, time for the systems I believe are likely the best: Kreissieg Cat-back F1 Sound Valvetronic Exhaust System: From what I have heard and what I see on the forums, this is as good as it gets. Best sound valves open and closed. Price: $5876 Valve Type: Electronic Valves Pros:
iPE Evo Valved Exhaust: This appears to be a very similar design to ARMYTRIX Price: 3-5k (They don't list prices online but this seems to be the range from what I can see) Valve Type: Electronic Valves (I think) Pros:
MEISTERSCHAFT GTC Valved Exhaust: Price: $2998 Valve Type: Vacuum Control (I believe you need to intercept an existing vacuum line as it doesn't include a separate pump) Pros:
E9X M3 Turner Motorsport Stainless Steel Valved Axle Back Exhaust: Now this is where things get interesting. This exhaust should solve the back pressure issue. I think this is also one of the best sounding with the valves closed. Price: $1150 Valve Type: Vacuum Control (You need to intercept an existing vacuum line as it doesn't include a separate pump) Pros:
And lastly, it's time for the exhausts that have been discontinued: Evolve E-Tronic Exhaust: This exhaust seems very similar in design to the Turner system, almost giving you two mufflers. From what I have seen, this was one of the best choices for the E92 M3 and I have not found many people listing cons. Valve Type: Vacuum Control (You need to intercept an existing vacuum line as it doesn't include a separate pump) Pros:
My hope here is to compile an exhaustive list of valved systems for the e9x M3 as I don't think there exists a great comparison at the moment. As a disclaimer, all of the info here I have taken from my research from other forum posts. I have yet to purchase any of these systems for my car. After putting this list together, I would rank the systems in the following order. I am considering overall value in my rankings as well. Kreissieg definitely sounds the best, but its by far the worst value:
I would love to hear some feedback/thoughts on these rankings from other forum members who actually have these exhausts. I am hoping to keep this thread up to date to help people making a decision come to a conclusion. I am hoping to pull the trigger on one of these systems soon! Curious to hear everyone's thoughts.
IG: weshascar
2012 Alpine White E92 M3 Coupe w/ Fox Red Extended Leather |
05-01-2023, 06:15 PM | #2 |
Rep 1,196
If you end up with the turner, it’s my opinion that you buy a vacuum pump off of Amazon/alibaba to power the exhaust valves instead of tapping into engine vacuum.
Less headaches and less lines running from the trunk to the engine bay. With the vacuum pump you can leave everything in the trunk and it operates the same way.
2009 BMW 335i 6MT
*big single (eventually)* For now... MHD tuned VRSF Race IC DCI ATM exhaust |
05-01-2023, 08:51 PM | #3 |
Rep 164
+1 to what Soden82 said.
I want to add my 2 cents regarding the Turner Exhaust minus what was discussed in that thread. Valves open or closed, that exhaust has a massive loss of back pressure. Going from OEM to Turner, I thought my head was messing with me but I didn't think much at the time. Last Sunday I installed test pipes, while my Turner exhaust was still installed. There was a slight bump in power but nothing to write about. Monday afternoon, my Supersprint Race exhaust showed up and installed it after work. The bump in mid range torque was significant enough that I though I was in a different car. This was all without a tune. YMMV, but it would be interesting to see that exhaust on a dyno, catless or not / tune or no tune. |
Soden82478.50 |
05-02-2023, 01:37 AM | #4 | |
Rep 150
IG: weshascar
05-02-2023, 01:42 AM | #5 | |
Rep 150
IG: weshascar
05-02-2023, 06:09 AM | #6 |
Rep 146
I had the GRWA exhaust paired with a no cat/res x-pipe at one point. With the valves closed it was definitely quiet. Made my morning commute less obnoxious and my neighbors definitely appreciated it.
I went with the vacuum version so I had no issues with the controller failing/etc during my 1 year ownership. Overall it wasn't a "bad" exhaust, but the sound profile I was looking for was just not there for me. |
05-02-2023, 08:20 AM | #7 | |
Rep 1,196
I can send you the link via DM if interested.
2009 BMW 335i 6MT
05-02-2023, 08:22 AM | #8 | |
Rep 1,196
2009 BMW 335i 6MT
05-02-2023, 03:21 PM | #9 |
Rep 150
Following some of the feedback from this thread, I reached out to MEISTERSCHAFT about the GTC exhaust. I am leaning heavily towards this as I hear good things about it and I like the sound from what I have seen online.
Interestingly, it appears GT Haus has shifted from a electronic valve design to GTC-VC. Similar to Turner, this system now requires you tap in to an existing vacuum line. I think buying a cheap vacuum pump is now the way to go here as well.
IG: weshascar
05-02-2023, 03:40 PM | #10 |
Rep 398
Won’t comment on any rankings since exhaust choice can be a highly subjective topic.. everyone will have a different preference or their own value perception on pitch/tone/noise level/drone/material/design/fit & finish/rarity/price point etc
I am lucky enough to have owned both the Power Craft and Kreissieg systems. No regrets here they have been both equally enjoyable in their own unique ways. Feel free to see some photos/sound clips in the “exhaust” archive in my IG profile https://instagram.com/ddddrmmm?igshid=YmMyMTA2M2Y=
IG @ddddrmmm
05-02-2023, 05:15 PM | #11 |
Rep 933
Drives: E90 M3
I have the Turner exhaust and I like it a lot. I’ve had it paired with an AA Xpipe and also with test pipes; can’t go wrong with either setup IMO.
I’ve heard valvetronic in person and that sounded really nice with valves open; valves closed it sounded like a Camry to me, but once again, subjective. |
05-02-2023, 08:55 PM | #12 | |
Rep 164
After two defective Turner exhausts, I'm not waiting for a miracle. Turner/ECS told me that it will be another year before a revised exhaust comes out. I've had the SS on for a week now and for me, it's a much more satisfying exhaust with a beautiful mid range tone that I now realize was missing on the Turner Exhaust. It's loud enough without being obnoxious, and one less button to press in a car with too many buttons that allow to change the user experience. No idea, but its a good question for someone with more expertise in that area. Last edited by GinTonic; 05-02-2023 at 09:05 PM.. |
05-03-2023, 01:27 AM | #13 |
Rep 142
Recently came across this brand, VE, for Valved Exhaust. From their videos, it looks promising.
https://valvedexhausts.ca/ comes in SS and Titanium and several tip options too. Video of M3 with valves Open and Closed
-Kai
05-03-2023, 08:07 AM | #14 | |
Rep 150
IG: weshascar
05-03-2023, 10:10 AM | #16 |
Rep 270
With the exception of a few of these most are just rebranded chinese alibaba crap. I had one of these setups when I first bought my car and it was awful. Way too loud and obnoxious and valves closed sounded worse than stock.
I think valved exhausts can be done right but I have gone back to the good ole standard muffler. *Edit: The evolve unit was probably the highest quality (made by supersprint) and had the most refined and clean sound. To my knowledge they are no longer made. |
05-03-2023, 10:12 AM | #17 |
Rep 150
Anyone here have experience with MEISTERSCHAFT GTC? I have heard good things but not many people seem to be running it. I am tempted to pull the trigger, but hoping to hear from someone with it.
IG: weshascar
02-12-2024, 10:10 PM | #20 |
Rep 415
Drives: 2011 BMW E92 M3 ZCP
Thought I'd bump this for anyone that comes across it in the future. A friend of mine did a group buy with GRWA a few years back and I got a vacuum valve stainless axleback from them.
First off, it is literally the same thing you would get from Bomiz, valvetronic, valvedexhausts.ca, etc., so there isn't really any reason to pay for one of these "branded" systems. GRWA doesn't put branding on so you get a cleaner look. The stainless system was pretty much what you would expect by itself with a stock X. It sounded good with valves open, and was ridiculously quiet with them closed. I don't think I ever really drove the car with them closed since it sounded weird to me. Fast forward to the next step, I got a resonated BW X with secondary HFC's, and this combo was HOT. The sound is amazing and I always got compliments from other E9X owners wanting to copy the setup. It has that F1-esque sound, not a Mustang throaty V8 sound that some other systems give. So basically, you have to pair the right X with GRWA's axleback if you want a really good sounding E9X. Here is this setup - Now the final stage, last year I reached out to GRWA and ordered the exact same system, but in titanium. THIS, is the play. Even more of that F1-esque sound, lightweight, KILLER. I paid $2,350 with the titanium X included. I sold that to someone to make some money back since I'm never getting rid of the BW X (power gains are just too noticeable). On the surface it might be a 'cheap' Chinese system, but getting a valved titanium axleback that looks really good and sounds as good as you would hope is way more worth it to me than spending $4k+ on the nicer systems. You just have to have the right X paired with it to get the best sound. My setup also doesn't drone, and has a little rasp, but the good kind. I also personally like the separate muffler look compared to the Turner look, so I've never had a reason to try something else out (and I REALLY like titanium now).
03-08-2024, 10:11 AM | #21 |
Rep 4
Hey Everyone, Sorry to awaken an old thread. I recently picked up a clean low milage E93 M3 and I'm looking to pick up a valved exhaust so I can hear that V8 sing. I've read through the whole thread and see people were able to get a GRWA system with the vacuum valves. I'm not seeing these listed on Alibaba. Can anyone hook up a new owner with a link or contact? Thanks in Advance!
03-08-2024, 12:53 PM | #22 |
Rep 42
They can produce basically anything you desire in China, depends quality and amount and negotiation. Pay some extra money and they will happy to start production from standard, to custom design.
Tags |
exhaust, valved, valvetronic |
