84 kVIEWS
120REPLIES
25APPRECIATES
14/07/2020LAST POST
Hujan wrote
That's what the $26k was for.
No, he said they sourced a new engine then build it. I asked how much a conversion would cost. If they have to start from a new engine then they have to pay back a value on my current engine which is not old. That's how true professionals do it. That's how Dinan does it.
Beautiful build.
Where did you see that?
The donor car for the conversion was a brand new Lime Rock Edition E92 M3 with a new engine. I believe they just pulled it, bored and stroked it, then re-assembled it.
http://www.m3post.com/forums/showthread.php?t=799746&page=16
Sales@Alekshop wrote
Now that we had the car we had to decide on how to replicate the higher HP 4.4L motor used in the GTS. We decided to not only match the additional factory power but go beyond with a 4.6L build and custom cams. We contacted our friends at ESS Tuning who confirmed that tuning would not be an issue so we got to work. We designed all of the internals, acquired a stock motor and built it out, when finished we were pretty excited how it all came together.
The first post of this thread implies that they acquired a donor engine.
Wrong. you were not attentive to the OP and getting in the way of my question.
Dinan stroker engine that's where. The conversion is done on a previous customer's engine, they swap with yours which becomes the base build for the next customer. Confirmed that weeks ago with a dinan stroker customer. They pay you some money back for your engine after they verified it's in good condition so you pay for the "conversion" only. Not a full engine when you already had one !
Dinan is by far the most professional in this market to judge others by.
Question was already asked to Alekshop. Apparently they're not answering.
If they take your engine and still charge you $26K it's a joke.
correct
i know for a fact they had a donor engine, i saw it when i was at the shop with a friend.
$26k + core is a pretty standard price for a stroker. Its in league with Dinan and RD's pricing.
Dinan charges you $26k + $10k core. So you essentially pay $36k. Once you send them your old motor, they return $10k - which puts your cost at $26k ( same price as alekshop)
Yes they got a bare engine for it. Not the one in the car.
I stand corrected about Dinan pricing.. The true priced value of the stroker is actually $26k + $10k = $36k or $26K for the conversion (turning over your previous engine). A +40% cost increase over the oem engine for only 15% more volumetry. clearly not remotely justifiable by even the most enthusiasts.
Regardless of what Alekshop said, it doesn't matter as you've seen. Conversion or core exchange, the price is the same . . . as I told you three days ago.
It's a very labor intensive process and the parts (crank, pistons, rods, cams) are expensive. What did you expect?
no it's not the same. conversion means your old core remains your possession: price $36K.
exchange means they take your old core: price $26K
Parts of engine should cost less than full engine. They're charging through the roof for the build 'labor' that's what.
true - core or conversion. the price is the same for the parts and labor. $26k after core or $26k to convert your existing engine which you would have to provide prior to the build. If it was $26k no core, no conversion - that would be a $16k stroker.
But back on original topic - This GTS clone is badass.
We purchased a separate stock motor for this build. We wanted to have a second motor on hand for future builds. The cost of a motor build like this would require a motor core exchange.
You guys selling this car? Wouldn't mind adding this to my garage. Pricing?
Very cool! Nice work.
Great build
RingMeister01 wrote
Boom
Issue's number?
Thank you in advance.
We already sold this car. We had to make room for some new projects :)
stunning!!
That looks stunning!
This is such a stunning car, the owner is truly truly lucky.
26k for a stroker 8-)
could you clear your inbox can't PM you
