246,7 kVIEWS
168REPLIES
19APPRECIATES
10/12/2025LAST POST
chriszeh wrote
weird i had the opposite experience. the fronts took me about half an hour to figure out and my rears just popped out.
I tried again today, rear is not coming out!!! :mad0259:
Thread referenced by mdosu in Brake job cost 17/07/2012
Will the rotors come off without removing the caliper bracket after removing the caliper?
Thread referenced by TC Kline Racing in Track brake pad/rotor wear - your results? 13/08/2012 · and 1 more related reference...
Thread referenced by Snertz in Changing brake pads...any how to links? 10/08/2012
Thread referenced by huyner328 in anybody have any good source for getting brake calipers painted? 14/08/2012
Can someone kindly make a detailed video on this? This would go a long way to prevent any mistakes.
question: after the pads are change and everything is re-installed correctly. is there play in the carrier? i.e., it can wiggle a little bit?
mine did that until I pumped the brakes a few times. hope this is normal.
Perfectly normal. Just be careful on first drive that you get the pistons to seat the pads before you take off. I just changed my pads last week and haven't driven it yet so I gotta remember this too, before I head to have my vorshlag plates set up.
Sending some love for this thread. I changed my pads over today and found the guide to be perfect. Getting the clips off was easy, the front i simply stuck a screwdriver into the middle clip and it flew off, the rear I stuck my screwdriver into one of of the holes and pried it off and the rest came out easy. The hardest part I found was the damn sliding caliper bolts - not much room to manouver in there. Oh and the pads I put on didn't have any retaining clips so getting the caliper back on was a bit tricky without having the pads fall out.
I made this video clip and posted it in the brake section. People were very confused as to how to retract the stock caliper's piston. Ironically nobody seemed to care after I posted this. Oh well, perhaps it'll help some people here!
Wow! Thanks! I never thought about using the carrier for leverage with a screwdriver. I always use a C-clamp as shown in the first post. Then I follow up with a caliper push back tool like this one to go all the way (for new pads).
Great idea! I will try 2 screw drivers concurrently on each side for symmetrical force application.
This will definitely make my swaps faster.
+1 screwdrivers work well. Much faster. Great thread. I wish I had read this sooner. I had to figure things out on my own.
Glad I could help :)
My sliding pins wont fit back in the carrier :(
I was swapping my rear pads and had no problems removing the 2 pins but I just couldn't screw them back in once the pads had been swapped. I tried swapping pin positions (top / bottom) but neither of them screwed back easily. I even tried screwing them without the calipher being on to see if they screwed in straight and had no luck. They became stuck halfway in and seemed to be on an angle that wasn't 90 degrees to the rotor.
I cleaned the carrier holes with a cloth and q tips. There was quite a bit of brake pad dust in there which i cleaned as best i could but that only helped a bit.
The pins weren't stripped of their thread but the threads weren't in flawless shape either.
I managed to screw them in with only 3 - 4 mm of the pin thread exposed and put plastic caps and the anti rattle clip back on. The caliper felt secure and I couldn't move it when i tried with my hand.
I'm going to have to take it to the stealership tomorrow to get it checked out I guess but I simply can't drive it far without the pins being fully in.
Question - can i drive it at all to the dealer or is it too risky with a rear caliper that's not fully secure. :( I suppse there's a risk the pads will stick as the caliper won't be able to slide back and forth easily but is that the worse that can happen?
Nice video. I noticed that the pads you installed did not have clips on them. Should I just take them off as it seems that it is even easier to put the pads back on without them?
With street pads I would recommend leaving the clips intact. Without them the pads can rattle a bit when no brake pressure is applied.
On my track pads I remove them to run titanium shims.
Big thanks again!!! I tried it just now in preparation for my track event tomorrow and it worked like a charm.
Just want to clarify that this method works even if the caliper has slid below the pad carrier (i.e. if the pads are worn quite a bit). I wasn't sure about it until I tried today. There is enough gap for leverage. NO MORE C-Clamp up front! (For the rears I still need that clamp though).
Awesome, glad to hear! :)
Thanks for all the information in this thread. I tried a 4-corner pad swap and brake fluid bleed recently. I had trouble getting the front clips back in, but the following DIY series was somewhat helpful on that too: DIY: Brake Pad Change e90 / e92 335i
It took me waaaayyy to long to get through the job this time, but the first time is always the slow time.
The pads I was pulling only had 4200 miles on them (new car). Be forewarned, the front outside pads are glued into the caliper with something really strong. You will need to forcibly separate them from the caliper. I had to use a pry bar as a wedge and get it started with a mallet. Phew.
This was mentioned in my video description along with other notes/tips ;)
What I do to push the piston back in the caliper is simply to leave the inside brake pad on and pull the caliper against the brake disc. It will very slowly retract and it's easy to fit thicker brake pads again.
No need of a special tool or anything, imho.
+1
Just watch kaiv's video. There is no need for ANY other method of piston retraction. This is the best.
Yes, thank you Kaiv.
I'll be swapping out the pads for track season next week and your screw driver trick should save a ton of hassle with the ol' C clamp.
Thanks a ton Kaiv!
