138KVIEWS
110REPLIES
110APPRECIATES
11-23-2025LAST POST
How does this part even go bad? Any guesses? Does it clog up?
Thread referenced by chamba002 in Valve cover gasket DIY 02-15-2017
I've been having this issue but mine normally happens at a half full tank. Do you guys still think it is the fuel tank breather valve
Thread referenced by WingZeroX5 in Dinan ECU Upgrade 02-28-2017
I've never heard of it happening at a half tank, but it's worth a try. It's a cheap part and an easy 3 hour job, so may as well give it a shot.
happened to me today again this time I was below a quarter of a tank. Im definitely thinking that valve is my issue, really annoying though.
Anybody else get a CEL associated with this issue? I'm not seeing any of the symptoms mentioned in the OP but got code 2772 - Activate tank vent valve.
Thread referenced by jinx1181 in Stalling at a stop 04-28-2017 · and 2 more related references...
Thread referenced by audioMeth in DIY: (E9x) M3 Thermostat Replacement 03-04-2017
Thread referenced by M3MPH1S in Bad fuel tank breather valve? 04-18-2017
Thread referenced by ///M3-=FiN=- in Idle fluctuation / TA related issue or ICV? 05-26-2017
I would like to say thank you for the write up. This actually fixed my problem. I actually had two problems. One was the ICV, which I had a code for it. and the other one was the idle fluctuation and stalling, which I thought it was due to the damaged ICV, but it wasn't. It ended up being the fuel tank breather valve. Once I changed this, it worked and the engine idle as smooth as when new. So if you have this problem with no code, please go ahead can change the fuel tank breather valve.
Thread referenced by Mvy in Fuel delivery problem 08-23-2017
Any chance anyone has the pictures for this thread? I don't see any of them popping up any longer.
Just open the pic in a new tab, it will appear
Sorry about the pics guys. Since Photobucket turned off third party hosting for non paying members, the pics are no longer working. I will at some point find another host and repost the pics.
I know this is bad timing and I will try to get to it asap.
https://chrome.google.com/webstore/detail/photobucket-embed-fix/naolkcpnnlofnnghnmfegnfnflicjjgj/related
Problem solved.
Thread referenced by drrust in RPM drops on idle 12-17-2017 · and 1 more related reference...
Thread referenced by TurboPR in Inconsistent Idle 11-15-2017
Thread referenced by TigerTrip in How can I fix a "fuel tank blockage" 01-29-2018
954MM wrote
pics still not showing =/
works for me with Firefox
Photobucket changed something that doesn't allow hotlinking anymore. If you have chrome or firefox you can get an extension that will make it work. For Chrome its "Photobucket Hotlink Fix"
I'm doing my spark plugs this weekend so will def do this too. For me though the needle bouncing around only happens if the car is on WHILE im getting gas. Sometimes it just bounces around and others it will stall. I've never had it happen after I left. Wondering if this is the same culprit.
Probably the car telling you to turn it off while refueling
I don't know if this is true or not but its happened to me once and I tested the fuel. Came out that it had 18% ethanol in there. Never happened again at a different station.
Are we supposed to turn it off while refueling? Does everyone on here turn the engine on their M's off?
If you're serious, then yes. It's a safety hazard to refuel while your engine is running. It's also illegal in many states. I see you're from New Jersey, so I'm guessing you don't pump your own gas often?
As is smoking while pumping lol. I recently saw an attendant at a Rally station smoking while cleaning up around the pumps at 2am.
YOLO
Any chance you could re-upload the photos?
Thanks!
No, I usually pump it myself just never considered the engine running a safety hazard. Especially in the colder months. My question was more of an inquiry to others that do leave the engine running sometimes, I can't be the only, do you encounter the same behavior.
This is very useful! but the pictures aren't loading for me...do you have this writeup in a pdf format you could e-mail?
