Ma boutique m'a dit de revenir après 1000 miles post tige portant le travail pour un changement d'huile.
Quelqu'un d'autre fait ça ? Pensées ? Recommandations ?
Powashiftin a écritMa boutique m'a dit de revenir après 1000 miles post tige portant le travail pour un changement d'huile.
Quels roulements ? Certains ont des procédures différentes et cela semble normal.
C'est la pratique courante pour obtenir le lubrifiant d'assemblage qui a été utilisé dans l'installation du roulement.
opihi5 a écritPowashiftin a écritQuels roulements ? Certains ont des procédures différentes et cela semble normal.Ma boutique m'a dit de revenir après 1000 miles post tige portant le travail pour un changement d'huile.
WPC avec ARP.
Les gars.
Powashiftin wroteYes, this is basically a standard break-in procedure. I would definitely follow that advice. Did they have you run a special break-in oil?My shop told me to come back after 1,000 miles post rod bearing job for an oil change.
Anyone else do that? Thoughts? Recommendations?
dparm wroteRegular 10w60 oil and OEM filter. I'm thinking about using liqui-moly going forward though.Powashiftin wroteYes, this is basically a standard break-in procedure. I would definitely follow that advice. Did they have you run a special break-in oil?My shop told me to come back after 1,000 miles post rod bearing job for an oil change.
Powashiftin wroteLiqui Moly 10w60 is much thicker than BMW 10w60. Probably better to stick to BMW or TWS 10w60.Regular 10w60 oil and OEM filter. I'm thinking about using liqui-moly going forward though.
Powashiftin wroteWhat's wrong with the Castrol TWS or BMW-branded Shell 10w60s?Regular 10w60 oil and OEM filter. I'm thinking about using liqui-moly going forward though.
dparm wroteBy regular I meant Castrol 10w60.Powashiftin wroteWhat's wrong with the Castrol TWS or BMW-branded Shell 10w60s?Regular 10w60 oil and OEM filter. I'm thinking about using liqui-moly going forward though.
Z K wroteIt is not 'much thicker', saying that really doesn't tell the full story. Go read up on cold viscosity vs hot. There is enough info out there so you can search if you wish to educate yourself and not spew misinformation.Liqui Moly 10w60 is much thicker than BMW 10w60. Probably better to stick to BMW or TWS 10w60.
tdott wroteI understand the Liqui Moly is slightly thinner at low temp and slightly thicker at high temp compared to Castrol TWS. In my own experience, I feel that the oil temp is slightly higher with liqui Moly when the engine is up to temperature. The needle tends to be slightly over middle mark more than what I remember with Castrol TWS...It is not 'much thicker', saying that really doesn't tell the full story. Go read up on cold viscosity vs hot. There is enough info out there so you can search if you wish to educate yourself and not spew misinformation.
tdott a écritSi aucun lubrifiant d'assemblage n'a été utilisé, il n'est pas nécessaire. Huiler les roulements avec de l'huile moteur est ce qui est recommandé.
Mais j'envisagerais toujours de faire un changement d'huile précoce juste pour être sûr. J'ai fait le mien à 1500 miles. après mon installation, l'installation a été faite avec de l'huile moteur en tant que lubrifiant, pas de lubrifiant d'assemblage.
J'ai 1200 miles sur mon travail de poste d'huile rb et n'ont pas encore fait le changement d'huile. 9 ans plus tard avec vos repères ? Merci.
E93415 a écritJ'ai 1200 miles sur mon travail de poste d'huile rb et n'ont pas encore fait le changement d'huile. 9 ans plus tard avec vos repères ? Merci.
Je n'ai pas eu de problèmes, mais j'ai mis environ 35k miles pendant ce temps. Les derniers 10 km étaient beaucoup de kilomètres et aller et revenir de la piste.
